Re: Disk brake question
[Re: 1970RT]
#2541842
08/27/18 01:11 AM
08/27/18 01:11 AM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
Well, your gonna have to measure the inner diameter of the spindle to determine wether you have a 72 or 73 spindle. The 72 uses a smaller diameter inner bearing, and a 73 uses a larger inner bearing. The 73-76 A body spindles (brakes) are pretty much considered the ones to find and use, as they have the large bearing. If you do have a 73 E body spindle, (or 74) those are a good one, as they are the same as the A body. Confused yet? lol
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: AndyF]
#2541849
08/27/18 01:47 AM
08/27/18 01:47 AM
hemi71x
Best factory brakes are the 11.75 rotors. The larger rotors fit any '73 or newer ABE knuckle so you already have what you need. Just buy the 11.75 caliper adapters from DoctorDiff if you don't have them then get the 11.75 rotors at a local parts store. That may be true, but a personal preference. But you neglect to tell the op that if you go that route you need 15 inch wheels to clear everything.
[Re: NANKET]
#2541857
08/27/18 02:33 AM
08/27/18 02:33 AM
RapidRobert
for the A body spindles, the 73-75 calipers have a 2.60" bore and the '76 ones at your parts house have a 2.75 bore so ask for that year, more front bias is almost always better. the outside dimentions/fitment are identical on those (3) years for that app, just a bigger bore/piston. EDIT (4) years
[Re: hemi71x]
#2541858
08/27/18 02:34 AM
08/27/18 02:34 AM
Posts: 939 Metro Detroit
1970RT
Metro Detroit
Well, your gonna have to measure the inner diameter of the spindle to determine wether you have a 72 or 73 spindle. The 72 uses a smaller diameter inner bearing, and a 73 uses a larger inner bearing. The 73-76 A body spindles (brakes) are pretty much considered the ones to find and use, as they have the large bearing. If you do have a 73 E body spindle, (or 74) those are a good one, as they are the same as the A body. Confused yet? lol I will have to measure the E-body brakes tomorrow to see what the diameter of the inner bearing is.
[Re: NANKET]
#2541859
08/27/18 02:35 AM
08/27/18 02:35 AM
1970RT
Metro Detroit
The smaller rotors on those A-body disc brakes stop a B-body just fine, and the stock 14" wheels fit on them if you,want to use them.
What wheels do you run on your GTX? 15" Cragars.
