Re: Has anyone ever seen a LX/LC Chassis with a big block?
[Re: TamrazsParts]
#2540860
08/24/18 01:26 PM
08/24/18 01:26 PM
Posts: 17,860 S.E. Michigan
ZIPPY
S.E. Michigan
As far as I know it hasn't been done.
Around the same time the often overlooked 5.9 magnum version of the drag pak was being validated enough to be made legal, I suggested to the powers that be...since we're using old engines that aren't available anymore, why not throw in a wedge and gen 2 version as well. They did listen, but that conversation didn't go any further.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2540927
08/24/18 04:09 PM
08/24/18 04:09 PM
Posts: 2,518 God's Country Maryland
GODSCOUNTRY340
I'm in the process of installing a 440 into a '54 flat fender Dodge Power Wagon. I realize this isn't a Challenger body but the same problems may be encountered. I will have to cut off nearly half the front crossmember to make this work, but that's okay since it's about 7" wide. The main problem is oil pump and harmonic balancer clearance, but it is doable.
[Re: TamrazsParts]
#2541042
08/24/18 09:18 PM
08/24/18 09:18 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
30.5" inner fender to inner fender with a few thou to spare on either side.
[Re: TamrazsParts]
#2541118
08/25/18 02:37 AM
08/25/18 02:37 AM
Posts: 2,255 IL
furious70
IL
Gen 3 is as wide as a big block though
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#2541330
08/25/18 06:29 PM
08/25/18 06:29 PM
Guitar Jones
Gen 3 is as wide as a big block though But the Gen 3 has the spark plugs on top and the exhaust ports angled down. Decidedly different from a BB.
[Re: TamrazsParts]
#2541773
08/26/18 10:58 PM
08/26/18 10:58 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I have an LX daily... I can't imagine anything fitting in there. The shop that will take this on will be comfortable with all the fabrication required - so mounts won't be something they're in the market for. Least IMO. Plus the air cleaner will be 1/2 way up the windshield...lol. The nose is LOW.
[Re: TamrazsParts]
#2542191
08/27/18 09:56 PM
08/27/18 09:56 PM
Posts: 33 Naperville, IL
TamrazsParts
Naperville, IL
Well, this input has been helpful. If for nothing more than to hear what the larger consensus has to say....it’s no doubt the Gen3 Hemi is a GREAT platform, especially with the aftermarket coming along. However the Nag1 trans isn’t that great/durable, but many of the available cars aren’t HEMI powered.
We personally believe with the count of how many big blocks exist as spares, along with the VERY plentiful amount of cars out there (the many that are 6 cylinder cores) that it would be a worthwhile investment to create a market solution for this combination - engine mounting system, a 727 transmission crossmember, a full length header set, and a power interface for basics.
For one thing, the car(s) have power windows, newer safety equipment (belts etc) and modern crumple zones. They also don’t have torsion bars.
When the inventory of lightly used 2009-2014 SE and SXT Challengers reach the market (watching closely, many of these cars are just exiting long term 72 month and 84 month financing now- meaning a 2010 7 year loan is a recent entry into the used car market) guys with recent drivelines might be interested in using them in a newer chassis.
Mid 100k mile 300C’s are going for less than 4k...running and driving. Many are showing up with blown engines at a price point of less than 2k. Challengers are still holding their value the best, and Chargers are somewhere in between.
Contact Chuck @ Tamrazs Parts . Com for any interest in prototyping these parts.
[Re: TamrazsParts]
#2542532
08/28/18 03:06 PM
08/28/18 03:06 PM
HotRodDave
Kalispell Mt.
Be carefull of just trying to do what you think would be cool and investing too much into something that the average guy does not think is worth the effort. I do this all the time, I buy neons durangos LX cars(2.7 to 3.5 swaps mostly), fix em all up real nice then wonder why no body else is interested in buying them. Just because I like the idea of something dont mean anyone else does. I still have a soft spot for magnum stroker motors but I doubt I would find much sales making custom parts to install them in just about anything else, heck the 3.5 V6 makes 5 more HP than a 5.9 and weighs about 1/2 as much. An early 5.7 makes as much power as a HP 440 (probably a few more actually) and weighs a couple hundred less so you will need a fairly serious motor just to keep up. Also if your swapping V6 LX cars to a BB you got to find a bigger diff as well as trans as that little V6 diff aint gonna last worth a hoot behind even a stock motor home 440.
