Small Block SCAT Or K1 Forged Crank? #2540472
08/23/18 03:26 PM
08/23/18 03:26 PM
Oklahoma City
Jwilli500 Offline OP
Oklahoma City
Thought I'd post this question here since it's more of a performance part. Both Forged 4" stroke with 318/340 mains. It'll be in a Street and strip application making around 450 horses?... The price difference is actually less than $10 so that's a wash. Which would you buy? If it makes difference at all I have a set of K1 H-Beam rods I'll be using in it. Thanks for looking guys!
Re: Small Block SCAT Or K1 Forged Crank? [Re: Jwilli500] #2540476
08/23/18 03:30 PM
08/23/18 03:30 PM
an8sec70cuda Offline
I've been pleased w/ the Scat products I've used in the past. Very nice stuff for the price.
Never used K1, but have heard they are decent quality also.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Small Block SCAT Or K1 Forged Crank? [Re: Jwilli500] #2540552
08/23/18 06:34 PM
08/23/18 06:34 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Scat makes nice stuff and is still in business. Thats what i would use, and is in a 418 stroker i have in the works
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Small Block SCAT Or K1 Forged Crank? [Re: Jwilli500] #2540563
08/23/18 06:59 PM
08/23/18 06:59 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I beat on my K-1 on my 550ish hp 408 for five years and it held up great, wouldn't hesitate to use another one. IMO either will be fine for your application.
Re: Small Block SCAT Or K1 Forged Crank? [Re: justinp61] #2540914
08/24/18 03:33 PM
08/24/18 03:33 PM
Oklahoma City
Oklahoma City
I really appreciate you guys input! Looks like it may come down to a coin toss. smile Anyone else?
Re: Small Block SCAT Or K1 Forged Crank? [Re: Jwilli500] #2540918
08/24/18 03:48 PM
08/24/18 03:48 PM
dogdays Offline
dogdays  Offline
Actually either one will stand more horsepower than your stock block can take.
They were very likely forged at the same plant in China. The only difference is where was the machining done and how picky the QC was.
So you can choose either one because they both are good companies turning out good finished products.
R.
Re: Small Block SCAT Or K1 Forged Crank? [Re: dogdays] #2540928
08/24/18 04:09 PM
08/24/18 04:09 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I bought two K1 cranks years ago off of Dan (Performance Only) during a Winter Special he had when the chevy journal cranks became available. I used The K1 crank and K1 rods with upgraded bolts and that assembly was rebuild 3 times over the years and was in need of its forth when it spun a bearing. That engine ran low 9.70's in my Duster and served me well. I will be using the second crank I got from him hopefully this Winter with some more compression, bigger cam, and hopefully run some 9.50's.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small Block SCAT Or K1 Forged Crank? [Re: Jwilli500] #2540951
08/24/18 04:51 PM
08/24/18 04:51 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I should have been more clear in my original post. Both are perfectly fine.
Scat is still in business, K1 isnt, from my understanding. So only for that reason would i go Scat. Both will do everything you need
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Small Block SCAT Or K1 Forged Crank? [Re: Jwilli500] #2540953
08/24/18 04:58 PM
08/24/18 04:58 PM
P
Porter67 Offline
Porter67  Offline
P
K1-s are sold by wiseco now.
As posted any of these cranks will outlast a oem block, ive been beating a eagle 4.00 forged in my street racer that runs 9.40-s at the track for over 12 years, check the mains every year, have replaced them twice and really didnt need to.
Good block machine work, align bore/hone good caps and go big on the clearances and they all should have a long service life with what we do.
Re: Small Block SCAT Or K1 Forged Crank? [Re: Jwilli500] #2542049
08/27/18 03:23 PM
08/27/18 03:23 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I have a Molnar crank in my low deck and it's a very nice piece. Tom is incredibly knowledgeable and great to deal with also. He was the original owner of K1 and worked for Oliver Rods.
http://www.molnartechnologies.com/cranks-domestic.html
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Small Block SCAT Or K1 Forged Crank? [Re: Eric] #2542063
08/27/18 03:54 PM
08/27/18 03:54 PM
Oklahoma City
Oklahoma City
Once again, thanks for all the responses guys! I think this is one of the best responses I've gotten to a question in a very long time. I appreciate your experiences. up
