cam ID help #2535219
08/12/18 07:11 PM
08/12/18 07:11 PM
birdtracker Offline OP
can anyone point me in the right direction identifying this Com Cam. I know its about .665 lift but was looking for a cam card. Thanks Birdtracker
Re: cam ID help [Re: birdtracker] #2535221
08/12/18 07:14 PM
08/12/18 07:14 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Possibly a regrind.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: cam ID help [Re: birdtracker] #2535233
08/12/18 07:36 PM
08/12/18 07:36 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Comp Cams 2226B/4134B R 108
Just go to the Comp lobe listing and look up the lobes.
The “B” just means it’s a big block master to help control profile growth when putting it on the Mopar core.
The N5095-08 is the serial number....... ground in 2008.
The R with the line under it means it was ground in the “race dept”.
The other “stampings” are core identification.
Re: cam ID help [Re: birdtracker] #2535278
08/12/18 08:40 PM
08/12/18 08:40 PM
So. Burlington, Vt.
So. Burlington, Vt.
Looks like......
289/296@.020
260/266@.050
.442/.430 lobe lift
Somewhat similar to the cam Andy used with the TF heads.
Re: cam ID help [Re: fast68plymouth] #2535292
08/12/18 09:06 PM
08/12/18 09:06 PM
thanks, this cam was gave to me for helping a guy out. It is going on a Trick Flow headed B engine. Thanks for all the info. Birdtracker
Re: cam ID help [Re: birdtracker] #2535371
08/12/18 11:28 PM
08/12/18 11:28 PM
last question. How much valve lash? thanks Birdtracker
Re: cam ID help [Re: birdtracker] #2535556
08/13/18 11:46 AM
08/13/18 11:46 AM
So. Burlington, Vt.
So. Burlington, Vt.
I’d do .018/.022 as a starting point.
