Re: cam ID help
[Re: birdtracker]
#2535233
08/12/18 07:36 PM
08/12/18 07:36 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Comp Cams 2226B/4134B R 108
Just go to the Comp lobe listing and look up the lobes.
The “B” just means it’s a big block master to help control profile growth when putting it on the Mopar core.
The N5095-08 is the serial number....... ground in 2008.
The R with the line under it means it was ground in the “race dept”.
The other “stampings” are core identification.
Re: cam ID help
[Re: birdtracker]
#2535278
08/12/18 08:40 PM
08/12/18 08:40 PM
fast68plymouth
So. Burlington, Vt.
Looks like......
289/296@.020 260/266@.050 .442/.430 lobe lift
Somewhat similar to the cam Andy used with the TF heads.
