Re: Mopar R 3 block #4532907 casting
[Re: Scamp408]
#253258
03/14/09 09:47 AM
03/14/09 09:47 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Not worth anything, BUT I would take it off your hands... I need a new anchor for my boat.... J/K I have no idea on the casting numbers
[Re: Scamp408]
#253260
03/14/09 10:01 AM
03/14/09 10:01 AM
MR_P_BODY
Is it a siamese block? Measure the front and back cam bearing holes, if they are the same size its a 50mm or 60mm cam . If its new you need to get it all line bored/honed, mine was way off
[Re: Scamp408]
#253262
03/14/09 11:55 AM
03/14/09 11:55 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
48* or 59* Siamese 2.500 mains 9.200 deck 230 lbs
[Re: blown360]
#253264
03/14/09 04:54 PM
03/14/09 04:54 PM
MR_P_BODY
Ive just bought the same casting number block from mancinis.Are all these cast number blocks the same?I was told the casting numbers dont actually mean nowt is thais true?
Yeah, its just a casting number but I think if it has this number its a siamese block, short deck(9" or 9.2)
[Re: DemonDust]
#253267
03/14/09 11:41 PM
03/14/09 11:41 PM
Posts: 2,709 NJ central
Scamp408
NJ central
I new the deck was 9.20 and I read on the sheet somthing about 2.25 mains .They also had the extra head bolt holes.The blocks were upside down so I couldnt tell the angle.The mains were 4 bolt steel not the iron.
[Re: mrsmallblock]
#253273
03/16/09 10:45 PM
03/16/09 10:45 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
If it was the ford 2.25 main, it had the 60mm cam and 9 inch deck. that was the only version that was ford main for the old craftsman truck program.
Howard mrsmallblock
I know where there's a smokin' deal on a Bryant crank for one of those.
