Re: 5.9 Cummins from a bus.....
[Re: JonGottaDemonDad]
#2529351
07/30/18 11:57 PM
07/30/18 11:57 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
hopefully it is a removable adapter as you need to be able to put the converter in the hole in the end of the crank so just cutting it off flush wont work.
#2529524
07/31/18 02:19 PM
07/31/18 02:19 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Just as a side note, the converter registers into the flex plate and not the crankshaft.
