5.9 Cummins from a bus..... #2529028
07/30/18 02:14 PM
07/30/18 02:14 PM
Escondido, California
JonGottaDemonDad Offline OP
I picked up a low mileage 5.9 24v cummins to put it into an old jeep. I picked up a dodge transmission to bolt onto it. When I tried to put it together the snout on the crank is like 3 inches long.
When I google photos of the stock 5.9 24v it looks different than my engine.
Any advice on how to correct this?
I was thinking about cutting it off with a bandsaw....
It was bolted to an Allison transmission when I bought it.
Craig
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529137
07/30/18 04:54 PM
07/30/18 04:54 PM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline
Blown_Hemi  Offline
Why not use the Allison transmission?
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529156
07/30/18 05:45 PM
07/30/18 05:45 PM
no overdrive and no parking brake. Not a solution for a daily driver.
Craig
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529235
07/30/18 08:29 PM
07/30/18 08:29 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i think that you have an adapter on the end of your crank that mates up the allison---dont let it fall off on your toe-----also on the 4bt site there are guys always looking for the high mount AC unit and the air compressor found on those bus motors---good score...
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529351
07/30/18 11:57 PM
07/30/18 11:57 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
hopefully it is a removable adapter as you need to be able to put the converter in the hole in the end of the crank so just cutting it off flush wont work.
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529357
07/31/18 12:08 AM
07/31/18 12:08 AM
you my friend are a legend......
savoy64
Thanks so much!
Craig
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529375
07/31/18 12:48 AM
07/31/18 12:48 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
my toe still hurts.....
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529457
07/31/18 11:50 AM
07/31/18 11:50 AM
i listened to your warning and I was not expecting the entire thing to pop off it hit me in the shin and missed my toes by like a 1ft.
Whew.....
Craig
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529524
07/31/18 02:19 PM
07/31/18 02:19 PM
Guitar Jones Offline
Just as a side note, the converter registers into the flex plate and not the crankshaft.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 5.9 Cummins from a bus..... [Re: JonGottaDemonDad] #2529866
08/01/18 09:53 AM
08/01/18 09:53 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If that water valve on the back of the head gets in the way it can be removed. There’s a large core plug in the pickup version.
