1967 Plymouth hubcap indentification #2527907
07/27/18 03:33 PM
07/27/18 03:33 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ok , Am trying to identify some hubcaps I have.
I have 2 sets of 4 of this one.
One set has a dark argent painted center.
the other set is light silver painted center ( like shown here )
Which one is correct for a 67 GTX
pictures are some I just grabbed off the net
Re: 1967 Plymouth wheel cover indentification [Re: gtx6970] #2527909
07/27/18 03:35 PM
07/27/18 03:35 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 1967 Plymouth hubcap indentification [Re: gtx6970] #2527910
07/27/18 03:35 PM
07/27/18 03:35 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
A dark argent set
( again just pictures I grabbed off the net )
These have a texture like rally wheel centers, various grills etc
Re: 1967 Plymouth hubcap indentification [Re: Alaskan_TA] #2527914
07/27/18 03:38 PM
07/27/18 03:38 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Barry, that doesn't help me in anyway.
Same goes for Nicks Garage
I see the same style cap is avail for 68 under a different PT #
And I assume the difference is paint, Questions is, which is which ?
Re: 1967 Plymouth hubcap indentification [Re: gtx6970] #2527915
07/27/18 03:38 PM
07/27/18 03:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Also used in '68 - http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1968/68_Belvedere0020.jpg
Possible paint difference year to year or different vendors or ?
Re: 1967 Plymouth hubcap indentification [Re: gtx6970] #2527918
07/27/18 03:41 PM
07/27/18 03:41 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Which version has the lower part number?
Re: 1967 Plymouth hubcap indentification [Re: gtx6970] #2527941
07/27/18 04:24 PM
07/27/18 04:24 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
any of them have a readable part number on the back?
2823028 * 1967 "light argent"
2881773 * 1968 "dark argent"
Re: 1967 Plymouth hubcap indentification [Re: gtx6970] #2527943
07/27/18 04:25 PM
07/27/18 04:25 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I was able to just barely read parts of the ink stamped part number on one of them.
A little detective work I made it out to be 2823028 which is the flat non textured silver finish ones.
Re: 1967 Plymouth hubcap indentification [Re: gtx6970] #2527975
07/27/18 05:19 PM
07/27/18 05:19 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Something I just figured out,
the ribs on the 67 ( light argent ) center cap spokes are bright chrome
The dark argent versions ( 68 caps ) the ribs of the cap are a satin chrome finish
The 67 caps are going with me, the others probably trash can fodder
Re: 1967 Plymouth hubcap indentification [Re: gtx6970] #2527981
07/27/18 05:38 PM
07/27/18 05:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
They have multiple uses, but.......
If you are just going to toss them, I would pay postage to here. ;-)
Re: 1967 Plymouth hubcap indentification [Re: gtx6970] #2527991
07/27/18 05:50 PM
07/27/18 05:50 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Barry, I would do that.
But theres only going to be 3 caps ( I want to keep an extra for a backup )
BUT, I leave for Arizona this weekend, Plus postage is likely not going to be cheap.
your call
Re: 1967 Plymouth hubcap indentification [Re: gtx6970] #2527997
07/27/18 05:59 PM
07/27/18 05:59 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Email sent, but if there is a '68 owner out there that actually needs them, that would be even better. beer
(I love wheel cover cars, so I would understand if they went to a better home.)
Re: 1967 Plymouth hubcap indentification [Re: gtx6970] #2528004
07/27/18 06:15 PM
07/27/18 06:15 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
scope
Re: 1967 Plymouth hubcap indentification [Re: gtx6970] #2529600
07/31/18 04:33 PM
07/31/18 04:33 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks Dan, doing some research I was able to determine which is which.
Kept the 5 best ones for myself and gave the others away
my ultimate goal is to own a 1967 GTX , sooner than later. When I do it will wear these hubcaps and some redlines
