Re: Max wedge heads on the street too much?
[Re: CoronetCrazed]
#2526548
07/24/18 07:00 PM
07/24/18 07:00 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
A much better way to go about this, IMO, is describe your intended performance goals and how the car will be used, and see what kinds of recommendations come back.
It’s best to have a budget in mind for the engine as well.
[Re: CoronetCrazed]
#2526559
07/24/18 07:15 PM
07/24/18 07:15 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Much bigger heads than that have been run very sucessfully on small mild street engines (eagle heads on a genIII 345 hemi for one example) so I would be shocked if you found them too big on a 44o if thats your concern, heck they would probably would be fine on a 361 with the correct supporting parts like cam, intake carb and such.
[Re: CoronetCrazed]
#2526569
07/24/18 07:39 PM
07/24/18 07:39 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
I think all above are correct in their guidance . I have the Trickflow 270 , max wedge . heads on my 505 daily driver/strip Plymouth . When first fitted the converter felt a bit softer . Got used to this pretty quick and didn't notice after a couple of days
BUT
My combo is not strictly normal for daily use . 68 Satellite , 4.1 gears , 29"street tyre , 5500 converter ( and seems higher now with dominator carb )
I have to pull motor as there is an internal moisture issue . If significant I will put this top end on my 440ci and keep going at least till end of season Lets face it a 270 head is still smaller than most BBChev heads used , they don't seem to have to many issues on 454 etc
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: CoronetCrazed]
#2526585
07/24/18 08:08 PM
07/24/18 08:08 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
never heard anything bad about the stealth seats, I have max wedge ports on my 512, indy 400-2 intake, 3.54 gear & od trans, love it.
[Re: AndyF]
#2526606
07/24/18 09:11 PM
07/24/18 09:11 PM
Posts: 4,699 Wichita
GY3
Wichita
If I were starting from scratch I go with the trick flow 270. However, since you already have the stealth I would go ahead and use it. Have them ported by somebody like Dwayne or modern cylinder head and have the locks and retainers replaced. Probably should match the spring so they can too. Personally, I've never heard of any problems with the valve seats in the stealth heads. I've got well over 5,000 miles on mine and they don't have an issue with that.
[Re: CoronetCrazed]
#2526715
07/25/18 01:19 AM
07/25/18 01:19 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
As stated it all depends on the combo and the performance you are looking for. I have seen some standard port combo's run as hard or harder then some Max Wedge port combo's in street cars only because the large Max Wedge port combo's were not a good matched up combo. Myself I got my EZ heads from Dwayne Porter and he opened up the ports to Max Wedge size but the heads are not heavily ported. But its what I wanted because I felt I run enough gear and converter for it to work and I also may want to step my combo up some more one day.
My eng is 4.15 stroke 440 (493 ci) and I do run 4.30's gears in my street car but I run 30" tall rear tires and a Dynamic 9.5 converter. And I am very happy with my car as it has run 10.70's driven to the track and raced just as I drive it through the full exh on 92 pump gas. And I don't change a thing at the track as I run it just as I drive it. I also don't run a roller cam as I use a solid flat tappet that's .585 & .592 lift with 264 & 270 @ .050 on a 110 LSA.
So I would say yes you can run Max Wedge ports on the street if you run the right combo so it works good. I feel mine works fine as my car has good low end and runs nicely as a driver. Good luck which ever way you decide on. Ron
[Re: CoronetCrazed]
#2526725
07/25/18 01:58 AM
07/25/18 01:58 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The standard port size is a very good size for 470 cubes, but going above 512 cubes the large (max wedge) heads have about the same cross section to cubes as a 383 with standard ports. Those 383s seemed to run pretty good,,,,,,
[Re: CoronetCrazed]
#2526754
07/25/18 08:00 AM
07/25/18 08:00 AM
Posts: 17,923 Akron, Ohio
ProSport
Akron, Ohio
My street car has a 500" low deck, pump gas 10:1 compression, 557 MP can, and Eddy heads with MW ports. Zero regrets!
I drove it to the track with 3.23 gears, ran 10.69 at 124mph and drove it home.
On the street I can launch in 2nd gear and it feels like a 10 sec pass. I love it.
[Re: AndyF]
#2526756
07/25/18 08:50 AM
07/25/18 08:50 AM
Posts: 2,141 junction city oregon
viperblue72
I did a back to back dyno test with Trick Flow 240 heads vs. 270 heads. The 270 heads made 25 more hp starting around 6000 rpm. Below that there wasn't a huge difference. Which means that on the street the 240 heads will work better since most street driving is off idle or part throttle. This was on a 470 inch pump gas engine which is fairly typical for a street car. https://www.hotrod.com/articles/dyno-day-trick-flow-270-mopar-heads/ I'm not necessarily disagreeing with you but he's gonna have 35 more cubic inches. I agree that either trick flow head would work great. But if it were me I would get the bigger cylinder head. Because if he decides he wants more later, he will have room.
