Re: LED Taillight "68 Coronet
[Re: poorboy]
#2526526
07/24/18 06:28 PM
07/24/18 06:28 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Change your 4 way flasher as well? Swapped in LED Taillights in place of the 1157's. Added the proper turn signal flasher. Looks like he did
[Re: Omni Source 1]
#2526646
07/24/18 10:48 PM
07/24/18 10:48 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
There are two types of flashers out there, the old style mechanicals like our cars came with. These have issues with LED lights as they use current flow thru the flasher to make them work. Half assed fixes like load resistors are used to up the current flow and crutch the flasher into woring. The other type are HD flashers, for towing and such. These do not use current flow thru the flasher to make them work. They are electronic in nature and function properly with LEDs. Just because you changed the flashers doesn't mean you put in the electronic ones. Example flasher
[Re: Omni Source 1]
#2527087
07/25/18 08:59 PM
07/25/18 08:59 PM
Supercuda
About to go away
About to go away
up yours
Switching the leads had nothing to do with the LEDs and everything to do with the flasher.
In it's stock setup one lead has 12V on it the other lead goes to the light. The OEM flasher is nothing more than a bimetallic strip that opens and closes contact as it heats up and cools off due to current flowing thru it to the bulb. LED's do not draw much current and will not work the OE style flasher.
If you swap the leads on the flasher you still have one lead with 12v and one going to the bulb. The difference is not how current flows thru the LED's, still the same as DC flows in one direction from negative to positive, but rather which pin on the flasher is getting the 12V and which pin on the flasher is going to the LED's on the flasher. Unlike the old school bimetallic strip in the OE flasher which is not polarity sensitive, the new fancy flasher is polarity sensitive and they appeared to have gotten the pins swapped for some odd reason.
[Re: Omni Source 1]
#2527280
07/26/18 11:06 AM
07/26/18 11:06 AM
Supercuda
About to go away
About to go away
up yours
Yes, the bulbs are polarity sensitive. LED is Light Emitting Diode and diodes only work with current flow in one direction. But you weren't talking about that.
