Trans Brake Usesr #2523154
07/17/18 04:52 PM
07/17/18 04:52 PM
New Smyrna Beach FL
scottb Offline OP
scottb  Offline OP
New Smyrna Beach FL
When using your trans brake when do you get on the brake when both drivers are staged or when the first light comes on bottom bulb racing
Re: Trans Brake Usesr [Re: scottb] #2523159
07/17/18 05:00 PM
07/17/18 05:00 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Matter of preference I suppose, I engage as soon as both cars stage and go to WOT when 1st bulb blinks
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Trans Brake Usesr [Re: bigdad] #2523186
07/17/18 05:31 PM
07/17/18 05:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was letting go as soon as the top bulb lit
if both cars were in the lights and hitting the
pedal at that time
wave
Re: Trans Brake Usesr [Re: scottb] #2523265
07/17/18 09:21 PM
07/17/18 09:21 PM
Cab_Burge Online work
Cab_Burge  Online Work
if you mean when do I get on the throttle after staging the car and engaging the trans brake button I wait until the first light on my side comes on and then go to WOT, this a S/P car with a Mega 400 box for the trans brake delay releasing the trans. brake after me releasing the button and the W.O.T switch gets activated shruggy
As far as applying the trans brake button I creep into the stage light very slowly(under 2000 RPM) and as soon as I see it light up I press the trans brake button, get my foot off of the brake peddle and wait until the top light comes on and then go to WOT and hold on boogie
Re: Trans Brake Usesr [Re: scottb] #2523269
07/17/18 09:39 PM
07/17/18 09:39 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
When do I set it? As soon as the stage bulb comes on, stab the brake, punch the button and mat it. That was protree racing.
Re: Trans Brake Usesr [Re: CMcAllister] #2523284
07/17/18 10:05 PM
07/17/18 10:05 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I am like Cab, and mat the throttle at the first bulb, my car rev's pretty quick so I just barely hit the two step, I don't like to sit for any time on the two step, I think it's rough on the internals of the engine and tranny, but thats just me. shruggy
Re: Trans Brake Usesr [Re: scottb] #2523344
07/17/18 11:31 PM
07/17/18 11:31 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Be aware of your competitors dial.... you run 10’s and mat the throttle when mr 14sec takes off, you’ll see some pretty impressive trans temps!
Stage on the button, mat the throttle when my side starts coming down.
Re: Trans Brake Usesr [Re: scottb] #2523375
07/18/18 12:44 AM
07/18/18 12:44 AM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
If I were bracket racing seriously, I'd have all the enhancer/crosstalk/whizbang tricks they'll let me use. Stage it, set the brake and mat it, jerk your thumb off the switch on yellow, hang on.
Re: Trans Brake Usesr [Re: scottb] #2523426
07/18/18 03:33 AM
07/18/18 03:33 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Set the trans. brake when you are staged. No matter who stages first. Guys I know actually bump into being fully staged with the trans. brake button. Obviously bottom bulb, no electronics guys.
