Page 2 of 4 1 2 3 4
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2521632
07/13/18 09:50 PM
07/13/18 09:50 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Much more air in those tires. M/T tire guy told me if they spin, put more air in them. He told me not to exceed 26 psi. You are not even close to where you should be with air pressure.
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: RustyM] #2521856
07/14/18 03:50 PM
07/14/18 03:50 PM
Italy
Raffaplymouth60 Offline OP
Italy
Originally Posted By RustyM
I would certainly try 1/4 pound of air in tires, see what she does- cant tell from pick where you are in relation to leaving on the light.
secondly- what front brakes do you have on the car?
If its the factory disc brake set up- you can easily lose some weight up front by going to aftermarket race brakes.
Not sure what your torsion bar options are for that car.
Yes, a little tuning on them can make a big difference, but you absolutely NEED scales.
Surely someone over there has a set of scales.
are you running a front anti-sway bar? If so, i would likely pull it off , save some weight, help front end respond better.
Do you have a picture of car just sitting still with 572 installed- a pit pic, from the side ?
no sway bar ... front draglite wilwood ... alu radiator .. fiberglass bumper ...
free image upload
1970 Cuda 496 street driven 9.22@150
1971 Demon 572 7.82@176
1957 Desoto Adventurer Convertible 345 Hemi
1958 Plymouth Fury Christine
2008 Dodge Ram 1500 Hemi
1970 Dodge ChallengerRT 6pack 4 speed 1 of 135
1968 Dodge Charger RT 4 speed
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2522051
07/15/18 10:15 AM
07/15/18 10:15 AM
Texas
RustyM Offline
RustyM  Offline
Texas
Beautiful car.
Stance doesn’t look bad at all.
Doesn’t sound like there remains big items for losing weight on the nose.
Hopefully some tire pressure tuning and chassis tuning can get you where you need to be.
Man I wish you could get your hands on some 4 corner scales.
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2522463
07/16/18 10:44 AM
07/16/18 10:44 AM
an8sec70cuda Offline
Get the tires up to about 13 psi and try again. Keep adding air from there.
Next suggestion is some double adjustable front shocks.
Strongly suggest progressing the nitrous.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2522494
07/16/18 11:57 AM
07/16/18 11:57 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Originally Posted By Raffaplymouth60
Originally Posted By Dduster
Put Your car on scales and let's see what the weight distribution is now with the new motor. With weight/load numbers You can decide the 'how much?' and 'where?' questions if necessary. Also, is this a torsion bar frontend car or coilovers/Struts/...????
no possible weight 4 corner in italy... Sorry.. i know only total weight 3650 LB
There should be many road course racers in Italy. They will have 4 corner scales. Make friends with one of them.
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2522544
07/16/18 01:43 PM
07/16/18 01:43 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Originally Posted By Biginchmopar
Set the CalTracs in the bottom hole (First).
Set the shocks on a pretty tight compression (Meaning hard to compress(1-10 set them at 8) rebound about in the middle (Second).
With you in the car and the bars set neutral put one or two flats of preload in the CalTrac bars (Three).
Set the tire pressure around 10 PSI (Four).
Report Back (Five).
Very good Infos ..Thanks for your Help .. therefore is better at 10 psi ? my tires is 29.5 /11.50/ 15 drag MT .. yes Calvert bar was adjusted at 1/4 preload with my ass ..
10lbs-12lbs of tire pressure will help the car not slam the tire in the ground.
The lower hole will help not hit the tire so hard (more push than bang) better lever.
Good luck and let us know how it goes
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Biginchmopar] #2533013
08/07/18 09:37 PM
08/07/18 09:37 PM
Italy
Italy
Report Back (Five).
Many Thanks for this infos .ok for 11/12 PSI i can put lower hole on caltracs .. 1/4 Preloads ?
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2533020
08/07/18 09:43 PM
08/07/18 09:43 PM
Italy
Italy
Megacuda New Look !
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2533023
08/07/18 09:48 PM
08/07/18 09:48 PM
Italy
Italy
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2533031
08/07/18 09:56 PM
08/07/18 09:56 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Very nice. I like
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: pittsburghracer] #2533036
08/07/18 10:05 PM
08/07/18 10:05 PM
Italy
Italy
Originally Posted By pittsburghracer
Very nice. I like
i Think .. when my car will wheeling like your Duster ... my 60 FT will be ok !
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2533117
08/08/18 12:48 AM
08/08/18 12:48 AM
Cab_Burge Online work
Cab_Burge  Online Work
Very nice. I like
Don't forget that your back may end up hurting from the new hard leaving work
I've had to learn that lesson more than once, realcrazy
Make sure and push yourself back into the driver seat before hitting it real hard twocents
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2533169
08/08/18 08:57 AM
08/08/18 08:57 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
New look is Super!!! The only thing I would add at this point is to only make 1 change at a time. Don't change air pressure, Caltrac setting and timing at the same time. You will never be able to determine what made better or worse times with too many changes.
[image][/image]
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2533284
08/08/18 02:24 PM
08/08/18 02:24 PM
Carson City, Nevada
Carson City, Nevada
Report Back (Five).
Yes 12PSI, Lower hole on the CalTracs and 1-2 flats of preload, so yes 1/8 to 1/4 rotation of preload.
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2533285
08/08/18 02:24 PM
08/08/18 02:24 PM
Carson City, Nevada
Carson City, Nevada
Great looking car!
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2545503
09/04/18 06:03 AM
09/04/18 06:03 AM
Italy
Italy
Hi Guys ... Bad news ... Bad 60 FT around 1.50 wheel spin also with more preload Torsion bars... 11 psi of rear pressure .. 1/4 Caltracs preload this is the video
https://youtu.be/zpw1VFESjQM
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2545510
09/04/18 07:44 AM
09/04/18 07:44 AM
UK
rb446 Offline
rb446  Offline
UK
Loosen the rear shock extension 1>2 clicks at a time so it stays on the tyre after the hit.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: rb446] #2545596
09/04/18 12:27 PM
09/04/18 12:27 PM
Italy
Italy
already tried .... no change with shock adjust ... i think front shock 90/10 doesnt work properly .. or torsion bars
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: Raffaplymouth60] #2545604
09/04/18 12:39 PM
09/04/18 12:39 PM
Front looks too loose to me.
CHIP
Re: Bad 60 FT with 70 lb more of Megablock on my Cuda [Re: an8sec70cuda] #2545637
09/04/18 01:53 PM
09/04/18 01:53 PM
Italy
Italy
I can not see the 8s !!! ... incredible .. engine is too fast for the frame ... Tires is 29.5x11.50x15 .. tonight i will check the front shock calvert 90-10 if work properly
Page 2 of 4 1 2 3 4
