Re: Need some help wipers
[Re: RapidRobert]
#2521506
07/13/18 04:23 PM
07/13/18 04:23 PM
Quicktree
You might see if you can find a model/year, its wiring diagram on www.mymopar.com I have a diagram, unfortunately it does not say where the wires go on the switch. I want them to go directly from the wiper motor to the switch bypassing all the factory crap.
[Re: 383man]
#2521679
07/14/18 12:27 AM
07/14/18 12:27 AM
Quicktree
Find the wiring diagram for one of the Mopars around your year for one with the 3 speed wipers. All the 3 speed wipers on Mopars I worked on use a shunt field to control speed along with some resisters built into the wiper switch to add and remove resistance in the shunt winding of the motor. I am sure I have one of my factory manuals with the wiring you need. If you cant get the wiring to easy PM me and I can take pics of the wiper wiring in one of my manuals for you and send them to you. Ron I have the diagram, it does not show the wires coming from the terminals on the switch to the wipers
[Re: Quicktree]
#2521795
07/14/18 01:18 PM
07/14/18 01:18 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
So, are you using a variable switch with a 3 speed motor? From what I could find, it seems like the switch has the same output continuity, but to act as a 3 speed, it needs a resistance wire in the harness for "medium", and an added resistor at the switch for "high"?
[Re: rbkt65]
#2546883
09/06/18 08:16 PM
09/06/18 08:16 PM
Quicktree
i have a 69 service manual that has a b c body. all wiring with variable wipers appear to be the same- it is as follows: b goes to ign switch acc. p goes to blue wire on w/s/w motor. f2 goes to green an w/s/w motor. A goes to brown on w/s/w motor. f1 goes to red on w/s/w motor. 2 terminals are jumpered to A as switch has resistance cable and remaining wire goes to washer motor. or u can hook it up with nozzles to spray water on tires like early camaros had. Haha. if u want a pic pm me and i will send pics of them. i dont know how to load pics into puter. i can sent anyone pics. just too old to learn this puter stuff. haha. just wanted to thank you again, finally got the car wired up and this worked perfect.
