Page 1 of 5 1 2 3 4 5
These plugs too cold? #2517774
07/05/18 12:44 AM
07/05/18 12:44 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Pulled from the 511 after a 60 mile trip to a car show. Mostly 3000rpm cruise. About 200 street miles on NGK 8's. Darkest plug is #7.
Re: These plugs too cold? [Re: mopar dave] #2517781
07/05/18 01:30 AM
07/05/18 01:30 AM
Washington
madscientist Offline
Washington
They look cold and rich but I don't really like reading NGK plugs.
Looks rich at cruise. Can't see WOT.
Re: These plugs too cold? [Re: mopar dave] #2517786
07/05/18 01:52 AM
07/05/18 01:52 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Unless you turn off the key while at full throttled and load at the top of at least 2nd gear,all you see on the plug is Idle.Dial in the timing 1st than fine tune the carb.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: These plugs too cold? [Re: mopar dave] #2517792
07/05/18 02:36 AM
07/05/18 02:36 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Well for sure to rich, probably one step to cold as well.
Re: These plugs too cold? [Re: Sport440] #2517800
07/05/18 03:27 AM
07/05/18 03:27 AM
Cab_Burge Online work
Cab_Burge  Online Work
iagree
Change the plug heat range first and go from there up
Re: These plugs too cold? [Re: mopar dave] #2517849
07/05/18 09:56 AM
07/05/18 09:56 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
8 is a cold plug unless you have some compression. If it’s a pump gas street motor you should atleast be running a 7 if not a 6. I run 6’s in my 10.5:1 511.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: These plugs too cold? [Re: Cab_Burge] #2517850
07/05/18 09:56 AM
07/05/18 09:56 AM
unless you can blast the plugs to clean em you might just change one plug (to the right heat range) tho the heat range may or may not be right as is right now, so you dont end up with multiple sets of fouled plugs till you get it taken care of. I'm thinking carb issue.
Re: These plugs too cold? [Re: RapidRobert] #2517852
07/05/18 10:07 AM
07/05/18 10:07 AM
Mt Morris Michigan
Mt Morris Michigan
Ok, i'll step this up to 7's. The 8's stayed clean for a long time until i took a longer trip. One at a time is a good idea. Thanks
Re: These plugs too cold? [Re: mopar dave] #2517855
07/05/18 10:22 AM
07/05/18 10:22 AM
Mt Morris Michigan
Mt Morris Michigan
Still have that one cylinder #7 that runs darker than the rest of the plugs while #5 burns the cleanest. #7 must be robbing fuel from #5 looks to me. I have done a bunch of reading on how to read plugs and no one says to look at porcilain burn color for mixture settings. The ring at the thread base is read for mixture and mine look pretty clean for the most part. No carbon build up there. Maybe #7 plug, but the rest look fair for a too cold of plug. What does porcilean color accually tell you besides if you have detonation or not? I will pick up some 7's and 6' and go from there. Thanks
Re: These plugs too cold? [Re: mopar dave] #2517872
07/05/18 11:10 AM
07/05/18 11:10 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
you may have fuel distribution issue with the intake manifold. single plane intake?
Re: These plugs too cold? [Re: lewtot184] #2517882
07/05/18 12:02 PM
07/05/18 12:02 PM
Mt Morris Michigan
Mt Morris Michigan
Yep . indy 400-2. Did some plenum porting on it and 4 hole taper spacer. Still an issue.
Re: These plugs too cold? [Re: mopar dave] #2517908
07/05/18 01:09 PM
07/05/18 01:09 PM
hemi-itis Offline
hemi-itis  Offline
I have multiple sets of fuel fouled plugs.I was able to install a set of them,turn off the key at the stripe and get an proper reading.This was with NGKs 7,8 & 9s. work
Re: These plugs too cold? [Re: mopar dave] #2517927
07/05/18 01:39 PM
07/05/18 01:39 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
You have a long process ahead of you but to start I would go down 2 on the pri side.Make a list of what you do.
Re: These plugs too cold? [Re: Clanton] #2517932
07/05/18 01:52 PM
07/05/18 01:52 PM
Mt Morris Michigan
Mt Morris Michigan
You wouldnt believe how well it runs. Without looking at the plugs you would never know they werent happy. Dom did a great job on this Dominator. Can let it set for an hour after driving and just hit the start button and it starts and idles without ever touching the throttle. Cruises at upper 13's to lower 14's. Dont think i need to open it up to tune any thing at this point. Maybe mixture screws or air bleeds. Timing is at 34*
Re: These plugs too cold? [Re: mopar dave] #2517937
07/05/18 01:59 PM
07/05/18 01:59 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run 7's in my 440/493 with EZ heads. Ron
Re: These plugs too cold? [Re: 383man] #2517942
07/05/18 02:07 PM
07/05/18 02:07 PM
Mt Morris Michigan
Mt Morris Michigan
Just put some ngk bcp7es in. Will see how these do. Thanks. Might have to run a 6 on the troubled #7 cylinder
Re: These plugs too cold? [Re: mopar dave] #2517970
07/05/18 02:41 PM
07/05/18 02:41 PM
Washington
Washington
Take the 4 hole spacer off and see if it fixes the distribution issues.
Also, you don't have to clean cut the engine unless you are tuning for WOT. Even then, if the rest of the tune up is correct you can drive it back to the pits and still read them.
Re: These plugs too cold? [Re: mopar dave] #2517975
07/05/18 02:49 PM
07/05/18 02:49 PM
Turn the left rear idle mixture screw in 1/4 to 1/3 turn leaner only and see if that helps #7 at part throttle cruise scope work grin
Another tuning secret hits the board whistling up
Re: These plugs too cold? [Re: madscientist] #2518029
07/05/18 04:33 PM
07/05/18 04:33 PM
Mt Morris Michigan
Mt Morris Michigan
I have ran it without a spacer, then a 4 hole, then a 4 hole taper. Same thing. Did some porting in the plenum. A little better but same issue. I will try that cab.
Re: These plugs too cold? [Re: mopar dave] #2518395
07/06/18 01:32 PM
07/06/18 01:32 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Hard to see the plug threads to count the number of threads the color change occurs at. From what I've read, it looks like its happening at the 3rd thread down from the tip, which should be ideal heat range wise.
As far as tuning for A/F mixture, buy and install a wide band and take the guess work out of it. Best tuning tool ever invented in my book.
