3 speed windshield wiper help #2517604
07/04/18 06:25 PM
07/04/18 06:25 PM
Duloc
The Shadow Offline OP
Duloc
Help
I want to convert my 67 dart to a 3 speed wiper.
I have a complete donor to get parts. Switch plug etc
Im sure this has done before but the search feature is very cumbersome and I didnt find anything
Im hoping its just an extra wire to add from the switch to the firewall.
Anybody do this mod?
Re: 3 speed windshield wiper help [Re: The Shadow] #2517610
07/04/18 06:42 PM
07/04/18 06:42 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
You need 3 speed motor with pivot arm that is on the motor. The arm is the hard part to find. Plus the switch. It should be all that you need at least on a B body. The harness from the motor is different but harness that you need is soldered to the motor.
I would remove the front cover but watch the clocking and clean out the old lub and put in fresh lub. The old lub gets hard.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: 3 speed windshield wiper help [Re: Bob J] #2517643
07/04/18 07:39 PM
07/04/18 07:39 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
If the motor has the white nylon cover on it be very careful it is fragile at this age
NS1AAR
Re: 3 speed windshield wiper help [Re: The Shadow] #2517654
07/04/18 07:59 PM
07/04/18 07:59 PM
Duloc
Duloc
I know its not plug and play as the wires on the left bulk head connector need to be moved. I have swapped everything over but for some reason the 2 speed switch has an extra wire going to it
Re: 3 speed windshield wiper help [Re: The Shadow] #2517790
07/05/18 02:01 AM
07/05/18 02:01 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
also you may need the link that goes to ds wiper pivot as some 2 and 3 speed ones are diff on a bodys .
ran into this on my 74 dart .
Re: 3 speed windshield wiper help [Re: The Shadow] #2518046
07/05/18 05:08 PM
07/05/18 05:08 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Try looking at the wiring diagrams here http://www.mymopar.com/downloads/1967/67_Dart_Charger_Wiring_Full.pdf
you should be able to find the loose wire. Mopar changed there pin outs in 68 so if you have a later motor its not plug and play. You can change the pin out for whatever motor you have as long as it matches the 67
NS1AAR
Re: 3 speed windshield wiper help [Re: The Shadow] #2518389
07/06/18 01:27 PM
07/06/18 01:27 PM
Duloc
Duloc
looks like the white wire is used reverse lighting wiring.
Why it goes through the wiper switch ...who knows
