Re: 3 speed windshield wiper help
[Re: The Shadow]
#2517610
07/04/18 06:42 PM
07/04/18 06:42 PM
Posts: 200 Colorado
Bob J
Colorado
You need 3 speed motor with pivot arm that is on the motor. The arm is the hard part to find. Plus the switch. It should be all that you need at least on a B body. The harness from the motor is different but harness that you need is soldered to the motor. I would remove the front cover but watch the clocking and clean out the old lub and put in fresh lub. The old lub gets hard.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
[Re: Bob J]
#2517643
07/04/18 07:39 PM
07/04/18 07:39 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
If the motor has the white nylon cover on it be very careful it is fragile at this age
NS1AAR
[Re: The Shadow]
#2518046
07/05/18 05:08 PM
07/05/18 05:08 PM
ns1aar
ontario calif
I know its not plug and play as the wires on the left bulk head connector need to be moved. I have swapped everything over but for some reason the 2 speed switch has an extra wire going to it Try looking at the wiring diagrams here http://www.mymopar.com/downloads/1967/67_Dart_Charger_Wiring_Full.pdfyou should be able to find the loose wire. Mopar changed there pin outs in 68 so if you have a later motor its not plug and play. You can change the pin out for whatever motor you have as long as it matches the 67
NS1AAR
