FITECH 6 pack #2471715
03/25/18 11:38 AM
03/25/18 11:38 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Re: FITECH 6 pack [Re: sogtx] #2471780
03/25/18 01:38 PM
03/25/18 01:38 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Is this a race topic ?
Re: FITECH 6 pack [Re: sogtx] #2471860
03/25/18 04:16 PM
03/25/18 04:16 PM
Earth
Rob C Offline
Rob C  Offline
Earth
No, but I'd like to tey it. Race topic, I don't think so.
Re: FITECH 6 pack [Re: sogtx] #2471865
03/25/18 04:22 PM
03/25/18 04:22 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
That's cuuuute...... work
I'm into it: someone buy one! up
Mo' Farts
Moderated by "tbagger".
Re: FITECH 6 pack [Re: sogtx] #2471867
03/25/18 04:26 PM
03/25/18 04:26 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
not out yet. unless someone can get a preproduction model. should work just fine like their other throttle bodies. looks to have progressive or maybe one to one linkage on the 2 bbls. biggest limiting factor on the six packs is the manifold design anyway, but coolness factor is way up there.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: FITECH 6 pack [Re: Jerry] #2471870
03/25/18 04:30 PM
03/25/18 04:30 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Thats interesting, fits square bore or spreadbore manifolds. Never seen a "spreadbore" 2300 two bbl. Go figure!
Re: FITECH 6 pack [Re: sogtx] #2471931
03/25/18 06:30 PM
03/25/18 06:30 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
not IMO, Cool idea twocents
Re: FITECH 6 pack [Re: TJP] #2471961
03/25/18 08:34 PM
03/25/18 08:34 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
I might bite bullet and put it on a small block
on a test stand ..
i have a fast ezi efi 4bbl
Not sure im in love with it .
Re: FITECH 6 pack [Re: sogtx] #2472009
03/25/18 10:15 PM
03/25/18 10:15 PM
BDW Offline
BDW  Offline
Make sure you understand, besides buying the 6pack intake, you'll need to mount the ECU.
A major selling point of FiTech is the completely integrated system.
I guess they couldn't get the electronics in the smaller 2bbl body.
From website:
FiTech Fuel Injection introduces the Go EFI 3×2 Tri Power 600HP with External ECU in Classic Carburetor Gold.
Re: FITECH 6 pack [Re: BDW] #2472014
03/25/18 10:22 PM
03/25/18 10:22 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Got an ez efi now
So should be easy ..
Re: FITECH 6 pack [Re: sogtx] #2472027
03/25/18 10:44 PM
03/25/18 10:44 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
And looks like it Will fit
They actually put the fuel on correct side
Wonder if theyll run backwards , lol
Re: FITECH 6 pack [Re: sogtx] #2472034
03/25/18 10:53 PM
03/25/18 10:53 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I run the F&B 6 pac on my 1970 Cuda 440 http://www.fbthrottlebodies.com/
And no I didn't pay that much when I bought mine.
I run it with FAST EFI controller. My system has been running 5 years with no issues.
As others have stated, there is a lot more you need to do than just bolting on the system.
My Monster are real!
Living within your means makes life pretty easy.
Re: FITECH 6 pack [Re: 67vertman] #2506769
06/10/18 08:26 PM
06/10/18 08:26 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Is the fitech out yet ???
Re: FITECH 6 pack [Re: sogtx] #2516903
07/03/18 03:00 PM
07/03/18 03:00 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Yes
Re: FITECH 6 pack [Re: sogtx] #2517190
07/03/18 10:10 PM
07/03/18 10:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yeah, I had a talk with them about the description, still haven't fixed it.
If they can't get it right trying to separate you from your cash I hesitate to wonder what they'll get wrong once they already have your cash.
cut and paste the email
You are correct, the website flyer should be up to date and I appreciate you bringing it to our attention that it has incorrect information. We are working to correct it currently.
-----Original Message-----
From: S Knickerbocker <sknickerbocker@suddenlink.net>
Sent: Tuesday, March 27, 2018 5:45 PM
To: info@fitechefi.com
Subject: Re: FiTech "Go EFI 3×2 Tri Power 600HP – External ECU"
The flyer I was looking at was the writeup on your website.
I assumed that would be the latest and greatest information at teh time.
> Hello,
> I will answer your questions in order:
> It is obvious that whomever wrote up the details on this unit was
> phoning it in. The obvious inaccuracies make it difficult to now what
> is correct and what isn't.
> There was a misprint on the flyers, we have corrected them but you
> must have received the incorrect one.
> "Fits square bore or spread bore intake manifolds." How does it do
> that? What would be useful is if you told use which 2bbl bolt pattern
> it actually has so we can see if it'll fit whatever intake we have. It
> looks to be the large Holley 2bbl pattern to me, you might add the
> drawing to your FiTech Throttle Body dimensions pdf.
> The bolt pattern for these throttle bodies is the Holley 2300 bolt
> pattern. If the intake you have chosen has this bolt pattern (such as
> the stock Mopar 340CID 6 pack intake) then the system will bolt to it.
> "High-flow aluminum throttle body with four 45mm throttle bores."
> Someone needs to check their fingers, I count 6, six, you know 2 more
> than 4, throttle bores and are they actually 45mm in diameter, based
> on the accuracy so far I have my doubts.
> The 6 throttle bores are 45mm in diameter
> "Works with original carb-type distributor, factory-style throttle
> linkage, and most 4-barrel intake manifolds." Again, how does it fit a
> 4bbl intake? Plus I seriously doubt it fits stock Mopar style linkage,
> you most likely need the Holley style throttle linkage adapter to make
> it work properly.
> Again the description was incorrect and we have corrected this in
> current printing. The system can work with most electronic ignitions
> including MSD Probillet 2 wire and ready to run distributors, MSD 6
> series ignition boxes (cannot work with 7 series MSD boxes), Pertronix
> Ignitor I, Pertronix Ignitor II, and most other after market 2 wire
> magnetic pickup/ ready to run distributors that copy the ones listed
> above. You cannot use any ignition system that still uses points, or
> has a ballast resistor anywhere in the ignition. Our systems require a
> 12v ignition signal to operate properly.
> Here are some questions you need to answer and add to the write up,
> after you fix the obviously incorrect items.
> Will it fit a stock Mopar 6bbl intake? The dimensional drawing will
> help answer that.
> Yes, it was in fact designed specifically to fit the Mopar 6bbl
> intakes, it was then also adapted to other manufactures aftermarket
> and factory 6bbl intakes (Ford, Chevy) Will a stock Mopar 6bbl air
> cleaner fit? The dimensional drawing will help answer that.
> Yes, like stated above it was designed to fit the stock Mopar 6 pack
> setup, thus we also designed it to fit the stock air cleaner as well.
> At $2k why doesn't it include timing control?
> The system does allow timing control but you must use a two wire
> magnetic pick-up distributor (such as MSD Probillet) AND a CDI box
> system, such as a MSD 6 series box.
> Where is the Go EFI Systems Manual for this setup? Not listed in your
> tech link, what you have listed is not for this setup.
> The instruction manual will be released when the system is on the market.
> If you have any further questions please let us know.
> *From:* FiTech Fuel Injection <info@fitechefi.com>
> *Sent:* Sunday, March 25, 2018 7:07 AM
> *To:* info@fitechefi.com
> *Subject:* FiTech "Go EFI 3×2 Tri Power 600HP – External ECU"
> Image removed by sender. <http://fitechefi.com/>
> From: Steve Knickerbocker
> Email: sknickerbocker@suddenlink.net
> <mailto:sknickerbocker@suddenlink.net>
> Subject: Go EFI 3×2 Tri Power 600HP – External ECU
> Message Body:
> it work properly.
> help answer that.
> Will a stock Mopar 6bbl air cleaner fit? The dimensional drawing will
> help answer that.
Don't be the exception.
Re: FITECH 6 pack [Re: Supercuda] #2517288
07/04/18 02:43 AM
07/04/18 02:43 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
Thanks for the feedback. I will buy one as soon as you see they are fit for the market.
Let us all know
Re: FITECH 6 pack [Re: jcastle1] #2517518
07/04/18 03:17 PM
07/04/18 03:17 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Man, if they can't even get the product description anywhere close to being right, it hardly instills any confidence!
That said, if it turns out to be a good product, its price is not too bad, since when Holley started making the carbs again years ago, they went to price gouging. I wonder what the cfm rating is on these? Is that a one piece throttle body or a 3 piece? Looks like one.
Re: FITECH 6 pack [Re: sogtx] #2517541
07/04/18 03:52 PM
07/04/18 03:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The price isn't bad, till you start adding the cost of the rest of it. I toyed with the idea of putting on on the small block I have for my Cuda. Yeah, not going to happen, the prices for everything is too much.
Re: FITECH 6 pack [Re: sogtx] #2654488
05/12/19 01:57 AM
05/12/19 01:57 AM
WA
Duane Offline
Duane  Offline
WA
Just got my fitech 3x2 injection today. Getting ready to install it. Just need the linkage
Re: FITECH 6 pack [Re: Duane] #2654506
05/12/19 08:01 AM
05/12/19 08:01 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
We like pictures...
