3 spd trans #2514623
06/28/18 08:50 PM
06/28/18 08:50 PM
O
otter440 Offline OP
otter440  Offline OP
O
I am doing a 66 coronet for a client six cylinder 3 spd trans in the tree he wants to put a 383 with the same 3 spd on it back in the car will this work with a big block bell housing? I told him to buy a 4 spd but client is always right Thanks
Re: 3 spd trans [Re: otter440] #2514671
06/28/18 10:36 PM
06/28/18 10:36 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
No unless it has a A745. Will kill a A903 almost immediately. I have a spare 66 A745. Not sure if a A903 would even fit a big block - might.
Many 4 spd big block housings have a dual bolt pattern for both a 3 speed and a 4 speed.
I have a 383 3 spd on the column 65 Fury cop car. Nothing wrong with a 383 3 spd on the column!
Note - at least in 65 (think 66 is the same) A745 were different between small and big block. The 1st gear ratio is different.
Re: 3 spd trans [Re: otter440] #2517426
07/04/18 01:03 PM
07/04/18 01:03 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
X2 on markz528's comments.
Only one add to it: if the customer is going to stay the course and stick with a three speed, get a 1970-up A230. 1970 is the first year of being all synchro. Pre-1970 does not have a synchro on first gear.
What you should get is a 1970 A230 from a 383/4 Cuda or Road Runner. These are a close ratio version. Not easy to find, but not in demand either.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: 3 spd trans [Re: otter440] #2517432
07/04/18 01:11 PM
07/04/18 01:11 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The new for 1970 3-speed in cars is the A230.
Re: 3 spd trans [Re: otter440] #2517486
07/04/18 02:37 PM
07/04/18 02:37 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Yup, A230; swapped a mint one out of an E-body into a '64 Savoy Poly 318 to get the synchro 1st. Fairly wide ratio spread. Looking through the FSM there are 2 A230s, with different strengths & ratio sets. When I later did a BB/727 transplant on the car, took a couple years to sell that trans for $150 with a floor shifter.
The 3-speeds seem to be gaining in popularity now.
Re: 3 spd trans [Re: otter440] #2517513
07/04/18 03:10 PM
07/04/18 03:10 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have 5 so far & another on the way next week. drive
Re: 3 spd trans [Re: otter440] #2517617
07/04/18 06:51 PM
07/04/18 06:51 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I got the whole package setting in a 72 Duster Twister /6 with AC. Would love to find a decent a-body to put it in.
Re: 3 spd trans [Re: Alaskan_TA] #2517619
07/04/18 06:52 PM
07/04/18 06:52 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
Thanks for the correction. blush
Ed
