UNDERSIZE B/RB REAR MAIN SEALS: AVAILABLE? #2517199
07/03/18 10:22 PM
07/03/18 10:22 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I have a crank which has a lil bit of pitting on the rear main seal area.
Is there an undersize rear main seal I can use so I can cut the crank undersize there and have a seal that will work?
Re: UNDERSIZE B/RB REAR MAIN SEALS: AVAILABLE? [Re: domingo] #2517357
07/04/18 11:05 AM
07/04/18 11:05 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
you want oversize, so you can undersize the crank
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: UNDERSIZE B/RB REAR MAIN SEALS: AVAILABLE? [Re: domingo] #2517429
07/04/18 01:06 PM
07/04/18 01:06 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Is it available anyplace?
Re: UNDERSIZE B/RB REAR MAIN SEALS: AVAILABLE? [Re: domingo] #2517888
07/05/18 12:12 PM
07/05/18 12:12 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
not that I know of. if the area is pitted, you would need to weld it and have it reground on size
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: UNDERSIZE B/RB REAR MAIN SEALS: AVAILABLE? [Re: Jerry] #2517917
07/05/18 01:23 PM
07/05/18 01:23 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Right, that is what I was trying to avoid....but I guess i will have to just do that....
Re: UNDERSIZE B/RB REAR MAIN SEALS: AVAILABLE? [Re: domingo] #2517921
07/05/18 01:27 PM
07/05/18 01:27 PM
dogdays Offline
dogdays  Offline
What kind of crank is it? Stock or 4340?
Is metal spraying an option?
R.
Re: UNDERSIZE B/RB REAR MAIN SEALS: AVAILABLE? [Re: domingo] #2517922
07/05/18 01:30 PM
07/05/18 01:30 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Its a Bryant pro Billet crank.
Re: UNDERSIZE B/RB REAR MAIN SEALS: AVAILABLE? [Re: domingo] #2517929
07/05/18 01:42 PM
07/05/18 01:42 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
There is only a .100 area that the seal tides on
Re: UNDERSIZE B/RB REAR MAIN SEALS: AVAILABLE? [Re: domingo] #2518010
07/05/18 03:39 PM
07/05/18 03:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A rope seal might work with a "lil bit" of pitting.
Re: UNDERSIZE B/RB REAR MAIN SEALS: AVAILABLE? [Re: John_Kunkel] #2518097
07/05/18 07:05 PM
07/05/18 07:05 PM
iagree
I learn to hate those type seal back when I was using and building the early Chrysler Firepower Hemi motors before I got enough knowledge on how to install them so they didn't leak shruggy
Make sure and get the crank seal area as flat as you can before on those seals before installing them up No rope short pieces long enough to get between the cap and block either tsk
Good luck on getting it sealed up up
Re: UNDERSIZE B/RB REAR MAIN SEALS: AVAILABLE? [Re: Cab_Burge] #2518455
07/06/18 03:38 PM
07/06/18 03:38 PM
dogdays Offline
dogdays  Offline
I would work hard to avoid welding a Bryant crank. I'm not sure the material is very amenable to successful welding. Bryant cranks are supposedly EN30B or their own special blend of 4330V or 4330M. Below is a link describing a welding process for 4330V. While fixing a hole seems like it may be much simpler, it may or may not require preheat and/or postheat.
https://vacaero.com/information-resource...components.html
I'd rather use JB Weld.
R.
Re: UNDERSIZE B/RB REAR MAIN SEALS: AVAILABLE? [Re: domingo] #2518489
07/06/18 05:02 PM
07/06/18 05:02 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Pitting is slight....but enough to feel it when you drag your fingernail over it, and I was worried that might cause damage to a rubber seal...
I was planning on polishing it...it might take around 3 thou i guess.
I wonder if I take 3 thou off it I will still be able to use a 2 piece rubber seal. I could shave some off the seal cap to achieve some more press on the seal against the crank....
....but if not, I guess I could always use a rope seal like suggested above....
Re: UNDERSIZE B/RB REAR MAIN SEALS: AVAILABLE? [Re: domingo] #2519740
07/09/18 10:52 PM
07/09/18 10:52 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
It took 4 thou to clean up the crank seal surface.
Do you guys think I can still use a regular 1 piece rubber seal?
Or do I risk it and I should better use a rope seal instead?
Re: UNDERSIZE B/RB REAR MAIN SEALS: AVAILABLE? [Re: domingo] #2519762
07/09/18 11:23 PM
07/09/18 11:23 PM
I would install the front and rear main bearings and upper seal with wheel bearing grease around the seal surface and install the top of the seal in the seal holder on the crankshaft installed in the motor with no side seals and tighten it up and then spin the crank around and then take hard look at the contact pattern on the seal surface on the crank after removing the top of the seal in the seal holder and go from there scope twocents
Good luck thumbs
Re: UNDERSIZE B/RB REAR MAIN SEALS: AVAILABLE? [Re: domingo] #2519772
07/09/18 11:31 PM
07/09/18 11:31 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
yes good idea, Ill do a checkup to make sure, but Im betting 4 thou wont hurt it.
...we'll see...
