N96 Guru's - Can I install a Fresh Air System on a Truck #2516542
07/02/18 07:27 PM
07/02/18 07:27 PM
Cannelton, IN
mike337 Offline OP
mike337  Offline OP
Cannelton, IN
Laying down the long range plan for my rest-o-mod for the 1979 Dodge Ramcharger I recently purchased. The hood is pretty plain, and while I would like a TA style center hood scoop, an aftermarket fiberglass hood with a TA center hood scoop is is not available for the truck.
The original hood has a raised center rib, so to reuse/modify the hood, I will have to go the route of two hood scoops.
I was recently watching Graveyard Carz, and saw the 1970 Coronet R/T convertible restoration, and thought the N96 hood scoops would look great on my truck.
Then, as an afterthought, wondered could the under hood fresh air system for a B-body, or A-body be mounted under the hood to make the two scoops functional?
Anyone with experience with the N96 option hazard a guess?
Mike
Re: N96 Guru's - Can I install a Fresh Air System on a Truck [Re: mike337] #2516544
07/02/18 07:38 PM
07/02/18 07:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
With some fabrication skills, time & money, why not?
Not functional in this case, but the scoops required a lot of hand fitting to match the hood contours.
Re: N96 Guru's - Can I install a Fresh Air System on a Truck [Re: mike337] #2516553
07/02/18 07:56 PM
07/02/18 07:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Seems to me it would be all that hard to trim a hood scoop to fit.
Re: N96 Guru's - Can I install a Fresh Air System on a Truck [Re: stumpy] #2516560
07/02/18 08:02 PM
07/02/18 08:02 PM
Cannelton, IN
mike337 Offline OP
mike337  Offline OP
Cannelton, IN
To clarify, the hood is relatively flat, and the scoops should bolt right on.
My question is would it be possible to mount the (under hood) system to the truck hood and make the system function-able to the air filter assembly.
Mike
Re: N96 Guru's - Can I install a Fresh Air System on a Truck [Re: mike337] #2516561
07/02/18 08:04 PM
07/02/18 08:04 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Well: You will have to fill about a foot of space with ducting or maybe space the aircleaner up about a foot towards the hood to make it functional.
Sheldon
Re: N96 Guru's - Can I install a Fresh Air System on a Truck [Re: RUNCHARGER] #2516668
07/02/18 11:34 PM
07/02/18 11:34 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I bought a Spectra Ram Air kit from Summit for my D150. Its a chrome closed air cleaner with two hoses that can be mounted were you want. I put a hole in the radiator support next to the radiator and installed a screen in front. It pulls fresh air from behind the grill. I was going to mount the other duct on the other side between the battery and radiator ,my 92 D150 has a duct on the right side between the battery and inner fender that pulls air from beneath the turn signal. thats were the factory single snorkel air cleaner got air from. I just hooked the other hose to it. My D150 has a 5.2 ( 318) I found a red and silver 318 air cleaner sticker at Carlisle and put it on, it almost looks factory
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: N96 Guru's - Can I install a Fresh Air System on a Truck [Re: 11secdart] #2517976
07/05/18 02:50 PM
07/05/18 02:50 PM
Cannelton, IN
mike337 Offline OP
mike337  Offline OP
Cannelton, IN
That may be just the right combo.
Thanx!
Mike
Re: N96 Guru's - Can I install a Fresh Air System on a Truck [Re: mike337] #2518184
07/05/18 10:19 PM
07/05/18 10:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Mike
USbodysource offers a bolt on, or a pin on fiberglass hoods for your truck, they offer a stock hood, a "Challenger R/T" scooped style hood and of course the lowly GM cowl hood, but they do have a custom build option of adding any scoop that they make to the hood of your choice (within reason), and they do make the T/A hoods....might be worth a call?
Mike
Re: N96 Guru's - Can I install a Fresh Air System on a Truck [Re: mike337] #2518214
07/05/18 11:17 PM
07/05/18 11:17 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Unlimited makes a bolt/rivet on T/A scoop. You'll note it has a spot for a raised line down the center for "flat" hoods. If you know anyone with a flat hood challenger you might want to throw a contour gauge on the center line and see how it compares to the ramcharger line.
I would think it would be way easier to get a single central scoop's air straight down to you air cleaner than trying to make two ducts that line up to the two scoop option.
http://www.up22.com/scoopw3.htm
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
