Re: Gen 2 in an Dart..steering column
[Re: Hot 340]
#2516629
07/02/18 10:46 PM
07/02/18 10:46 PM
Posts: 43,300 Bend,OR USA
Cab_Burge
What year Dart and what was the original tranny in that car, if you know? I converted a 1966 Dodge Coronet Deluxe from a slant six with a three speed in it to a 440 4 speed, I took the original steering column apart to remove the sleeve and all the parts inside that controlled the linkage to the old 3 speed stick tranny that looks like yours a little bit ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: Cab_Burge]
#2516769
07/03/18 06:45 AM
07/03/18 06:45 AM
Posts: 3,396 Pa
Hot 340
Pa
What year Dart and what was the original tranny in that car, if you know? I converted a 1966 Dodge Coronet Deluxe from a slant six with a three speed in it to a 440 4 speed, I took the original steering column apart to remove the sleeve and all the parts inside that controlled the linkage to the old 3 speed stick tranny that looks like yours a little bit Thanks guys. Its a 72 Demon, original 340 727 car according to the fender tag. Dont think its a 3 speed column Cab...pretty original car that I know the previous owners to. Even the original owner.
