Gen 2 in an Dart..steering column #2516066
07/01/18 09:38 PM
07/01/18 09:38 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
My column sleeve needs trimmed as Ive read on here before to do a hemi abody swap.. The mock up block touches and will pull the column to trim it back..my question is what is this smaller sleeve on the column? It moves in and out if I pull on it. Heres a pic of it in and a pic pulled out.
Re: Gen 2 in an Dart..steering column [Re: Hot 340] #2516515
07/02/18 06:26 PM
07/02/18 06:26 PM
Everywhere
Lost in life Offline
Everywhere
I believe that is part of the collapse portion of the steering column but could be entirely mistaken!
Re: Gen 2 in an Dart..steering column [Re: Hot 340] #2516629
07/02/18 10:46 PM
07/02/18 10:46 PM
What year Dart and what was the original tranny in that car, if you know?
I converted a 1966 Dodge Coronet Deluxe from a slant six with a three speed in it to a 440 4 speed, I took the original steering column apart to remove the sleeve and all the parts inside that controlled the linkage to the old 3 speed stick tranny that looks like yours a little bit work
Re: Gen 2 in an Dart..steering column [Re: Cab_Burge] #2516769
07/03/18 06:45 AM
07/03/18 06:45 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Thanks guys. Its a 72 Demon, original 340 727 car according to the fender tag. Dont think its a 3 speed column Cab...pretty original car that I know the previous owners to. Even the original owner.
Re: Gen 2 in an Dart..steering column [Re: Hot 340] #2516872
07/03/18 02:00 PM
07/03/18 02:00 PM
If your car was a column shift car remove or cut that tube as needed and move on twocents up
Re: Gen 2 in an Dart..steering column [Re: Cab_Burge] #2517146
07/03/18 07:40 PM
07/03/18 07:40 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Floor shift all its life. Doubt it needs cut,as its out of the way. Just curious what it was for. Ill just trim the big outer. Thanks guys
