Re: 3 spd trans
[Re: otter440]
#2514671
06/28/18 10:36 PM
06/28/18 10:36 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
No unless it has a A745. Will kill a A903 almost immediately. I have a spare 66 A745. Not sure if a A903 would even fit a big block - might.
Many 4 spd big block housings have a dual bolt pattern for both a 3 speed and a 4 speed.
I have a 383 3 spd on the column 65 Fury cop car. Nothing wrong with a 383 3 spd on the column!
Note - at least in 65 (think 66 is the same) A745 were different between small and big block. The 1st gear ratio is different.
Re: 3 spd trans
[Re: otter440]
#2517426
07/04/18 01:03 PM
07/04/18 01:03 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
X2 on markz528's comments.
Only one add to it: if the customer is going to stay the course and stick with a three speed, get a 1970-up A230. 1970 is the first year of being all synchro. Pre-1970 does not have a synchro on first gear.
What you should get is a 1970 A230 from a 383/4 Cuda or Road Runner. These are a close ratio version. Not easy to find, but not in demand either.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: 3 spd trans
[Re: Alaskan_TA]
#2517619
07/04/18 06:52 PM
07/04/18 06:52 PM
EWJ
Back in NJ....
The new for 1970 3-speed in cars is the A230. Thanks for the correction. ![blush blush](/ubbthreads/images/graemlins/custom/blush.gif)
