What's up with my air conditioning? 2001 Durango #2513352
06/26/18 04:07 AM
06/26/18 04:07 AM
Spartan040 Offline OP
Hey everyone, I've got a question about my air conditioning in my 2001 Durango SLT, 4.7L RWD. It never seems to be blowing as cold as it should, even though I have a brand new compressor and it's full of R134a (so far s I know). I don't believe it's my receiver-drier or accumulator, I don't have the associated smell. It's not the blower motor either. We checked the blend doors inside the dash, they seem to be working properly. It just never gets very cool during these hot summer days in Florida. It blows semi-cool in the mornings and evenings, and it's certainly cold in the winter, but I'm roasting in there during the daytime. It should be much colder than it is.
Oh, and I'm only getting hot air out of the front passenger side vents no matter what I do with the controls.
What could be the problem here?
Re: What's up with my air conditioning? 2001 Durango [Re: Spartan040] #2513384
06/26/18 09:49 AM
06/26/18 09:49 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
it could be a LOT of things.
probably low freon levels.
it could be to much freon in the system also.
could be plugged up orifice tube also.
perception is 90% of reality
Re: What's up with my air conditioning? 2001 Durango [Re: Spartan040] #2513390
06/26/18 10:10 AM
06/26/18 10:10 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Like said it could be a lot of things. I have a 2005 durango and the hose from the compressor to the condenser starting leaking last year. I pulled out all the gas with my recycler/AC machine and could see it was low. Recharged it and it worked for another year. Lately it got low again and I ordered a new hose for it. Luckily the hose was only 32 bucks shipped to my door. Should have replaced last year.
But your problem sounds like a door problem if you have hot air out one vent and cool air out of the rest. It sounds like the hot air is blending with the cool air? My twocents
Re: What's up with my air conditioning? 2001 Durango [Re: Spartan040] #2513405
06/26/18 10:59 AM
06/26/18 10:59 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
without knowing pressures, anything is a guess
Re: What's up with my air conditioning? 2001 Durango [Re: gtx6970] #2513424
06/26/18 12:17 PM
06/26/18 12:17 PM
Pressures are all where they're supposed to be, at least they were when we filled up the freon.
Re: What's up with my air conditioning? 2001 Durango [Re: Challenger 1] #2513425
06/26/18 12:18 PM
06/26/18 12:18 PM
We checked the blend doors, they seemed to be working fine
Re: What's up with my air conditioning? 2001 Durango [Re: Spartan040] #2513433
06/26/18 12:33 PM
06/26/18 12:33 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Not familiar with '01 (I have a '00) controls. Does it have his and hers temp controls?
Thinking slow this morning.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: What's up with my air conditioning? 2001 Durango [Re: I_bleed_MOPAR] #2513438
06/26/18 12:44 PM
06/26/18 12:44 PM
Buford, GA
Buford, GA
Thinking slow this morning. I agree that it sounds like it's low on freon. I would try to add a little more at the time and see if it starts to cool off more.
Maybe your gauges are off?
Tim
'71 Charger 383/727
Re: What's up with my air conditioning? 2001 Durango [Re: I_bleed_MOPAR] #2513443
06/26/18 12:50 PM
06/26/18 12:50 PM
Tim
I was using a mechanic's gauges at my uncle's auto shop, so I don't think it's that. We tried adding freon once before, and while it helped temporarily, within a few minutes it went back to warmer air. Which is weird, since the pressures all still read as normal.
Re: What's up with my air conditioning? 2001 Durango [Re: Spartan040] #2513458
06/26/18 01:10 PM
06/26/18 01:10 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I'm all ears, my 01 is the same.
Re: What's up with my air conditioning? 2001 Durango [Re: Spartan040] #2513465
06/26/18 01:24 PM
06/26/18 01:24 PM
fla
ss/la Offline
ss/la  Offline
fla
it is either low on 134 or fan clutch is going bad
Re: What's up with my air conditioning? 2001 Durango [Re: ss/la] #2513483
06/26/18 01:49 PM
06/26/18 01:49 PM
It's definitely not the fan clutch, it got replaced less than 2 years ago.
Re: What's up with my air conditioning? 2001 Durango [Re: Spartan040] #2513488
06/26/18 01:59 PM
06/26/18 01:59 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I wonder if they used a very similar AC hose on 2005 T&C minivans because my mothers 3.3L has a similar slow freon leak?
A dose of Red Angel 2nd generation stop leak slowed it down from 12 oz every 2 weeks to 12 oz every 12 weeks.
Re: What's up with my air conditioning? 2001 Durango [Re: 360view] #2513499
06/26/18 02:25 PM
06/26/18 02:25 PM
I doubt I have a leak, we did a pressure test and all seemed normal
Re: What's up with my air conditioning? 2001 Durango [Re: Spartan040] #2513515
06/26/18 03:01 PM
06/26/18 03:01 PM
Buford, GA
Buford, GA
Hmmm.... might try pinching off the heater hoses to double check blend door.
Driving down the road makes no difference?
Tim
'71 Charger 383/727
Re: What's up with my air conditioning? 2001 Durango [Re: I_bleed_MOPAR] #2513519
06/26/18 03:31 PM
06/26/18 03:31 PM
Tim
Not on the passenger side, no. If I'm stuck in traffic the driver's side air gets warmer, and it gets a tiny bit cooler after I get going again, but it's still way too warm.
Re: What's up with my air conditioning? 2001 Durango [Re: Spartan040] #2513523
06/26/18 03:42 PM
06/26/18 03:42 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
And the elec fan is working right?
Re: What's up with my air conditioning? 2001 Durango [Re: Spartan040] #2513524
06/26/18 03:42 PM
06/26/18 03:42 PM
Buford, GA
Buford, GA
Pretty much rules out fan clutch as well as the auxiallary electric, I would think. After about 20 mph airflow cools the radiator and condenser. Probably would have noticed engine temp rising anyway at a stop or in stop-n-go traffic.
Try pinching the heater hoses off.
Tim
'71 Charger 383/727
Re: What's up with my air conditioning? 2001 Durango [Re: I_bleed_MOPAR] #2513530
06/26/18 03:49 PM
06/26/18 03:49 PM
Buford, GA
Buford, GA
You did vacuum the system down when you replaced the compressor? How much oil did you add?
Tim
'71 Charger 383/727
Re: What's up with my air conditioning? 2001 Durango [Re: buildanother] #2513532
06/26/18 03:54 PM
06/26/18 03:54 PM
So far as I can tell, yes
