65 B-Body Master Cylinder Conversion #2510978
06/20/18 06:53 PM
06/20/18 06:53 PM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
Hello All
I would like to change the master cylinder on my 65 Coronet to a dual master cylinder. Does anyone know of a conversion kit? or of a supplier of the master cylinder that I would need? Do I need a specific kit or can I use a master cylinder from a different car. If so, what car? What should I look for in a good conversion kit? What are some of the pitfalls I should watch for?
Thanks for the help.
Re: 65 B-Body Master Cylinder Conversion [Re: vjb] #2511067
06/20/18 09:57 PM
06/20/18 09:57 PM
AndyF Online content
AndyF  Online Content
I'd start with DoctorDiff and go from there. You might need a firewall plate depending on if you have a power brake car or a manual brake car.
Re: 65 B-Body Master Cylinder Conversion [Re: AndyF] #2511255
06/21/18 11:27 AM
06/21/18 11:27 AM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
Thanks for the info. I'll check them out now. The car has power brakes. I think that Wilwood has the parts also.
Re: 65 B-Body Master Cylinder Conversion [Re: vjb] #2511603
06/22/18 02:43 AM
06/22/18 02:43 AM
I wouldn't recommend Wilwood. Stick with factory parts, you'll be better off in the long run. You can get the correct parts from Doctor Diff. You need a firewall plate, the 4 to 2 bolt adapter and the new aluminum/plastic master cylinder. You might also need a different pushrod. The conversion would be a lot easier if you had a manual brake car since then you would have the correct firewall plate and the correct pushrod.
You should probably post this over in the general or racing section since it isn't a restoration topic. Adding a late model MC to an early car is restomod.
Re: 65 B-Body Master Cylinder Conversion [Re: AndyF] #2511761
06/22/18 02:58 PM
06/22/18 02:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
OP didn't state whether or not he wants to retain the power brakes.
If retaining the power brakes and original drum brakes, a stock replacement drum brake MC from a '67 PB car, like the Raybestos MC36221, will do the job. It'll bolt right to your '65 booster.
Re: 65 B-Body Master Cylinder Conversion [Re: vjb] #2512153
06/23/18 01:20 PM
06/23/18 01:20 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Buddy of mine switched his 1966 over.
Used all 67 parts. Keeping the drum brakes , his is manual though
Bought an nos 67 Master cyl , used a 67 prop valve and lines from Finelines for a 67.
Works like a charm
Re: 65 B-Body Master Cylinder Conversion [Re: gtx6970] #2512182
06/23/18 02:32 PM
06/23/18 02:32 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I changed over on my 65 300. Used the power brake MC from a 67-68 and got some lines from Stainless Steel lines for the MC to the distribution block.
Abe Lincoln
Re: 65 B-Body Master Cylinder Conversion [Re: vjb] #2512793
06/24/18 10:59 PM
06/24/18 10:59 PM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
Thanks for the suggestions. I have a lot to look at.
Thanks again.
Re: 65 B-Body Master Cylinder Conversion [Re: vjb] #2512836
06/25/18 12:35 AM
06/25/18 12:35 AM
Here is the engine bay in my '65 Coronet. It isn't a close up shot but you can see the aluminum/plastic master cylinder that I used. It has the 4 to 2 adapter but as others have pointed out, if you use a cast iron MC then you don't need the adapter. I stopped using cast iron master cylinders years ago since they rust during storage, but if you drive the car on a regular basis and change the brake fluid every couple of years you'll be okay.
Re: 65 B-Body Master Cylinder Conversion [Re: AndyF] #2513058
06/25/18 03:16 PM
06/25/18 03:16 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Hey Andy, what are those aluminum ears sticking up on your car?
Abe Lincoln
