BB solid roller lifter
#2511352
06/21/18 03:24 PM
06/21/18 03:24 PM
Posts: 7 Australia
Dartski68
Australia
I have factory lifter bore has anyone used solid roller lifter by crower 66233? This lifter is available on shelf in Australia so it's my first choice.
I'm also considering comp lifter 96829 or comp amc 861
Solid roller cam duration 263 on intake @ 0.50 with 650 lift, street use with lighter street spring pressure
Re: BB solid roller lifter
[Re: Dartski68]
#2511391
06/21/18 04:41 PM
06/21/18 04:41 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
I would not use a needle bearing roller lifter for the street. it would be just a matter of time before it fails and sends tool steel shavings throughout your motor. I only use bushed lifters....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Dartski68]
#2511583
06/22/18 01:16 AM
06/22/18 01:16 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
How man miles, not KM , are you wanting to operate this motor between changing or rebuilding these lifters? I put around 3000 street miles on a older set of Crower Ultra solid body needle bearing roller lifters with no issues shifting it at or above 7000 RPM at the track, lots of 1/8 and some 1/4 mile passes each year
[Re: Dartski68]
#2511675
06/22/18 11:38 AM
06/22/18 11:38 AM
Posts: 8,926 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I would not use a needle bearing roller lifter for the street. it would be just a matter of time before it fails and sends tool steel shavings throughout your motor. I only use bushed lifters.... Hmmm ... at the Indy Mopar show I asked the Crane rep about using the bushed versus needle bearing lifters on the street. I always figured it would be a better alternative too. He TOTALLY disagreed saying the bushed lifters would not hold up under low rpm use. Part of the reason being that the bushing is solid bronze, not sintered - which couldn't take the beating of a lifter. Therefore it doesn't retain lube and would just burn up. The needle bearing on the other hand would retain some lube in the space between the rollers. As to the OP's question, with a stock, unbushed lifter bore you need a lifter that has the roller wheel shrouded, otherwise it will expose the oil galley at high lift. I don't know about the lifters you're looking at but the Crane 66550 lifter meets the criteria.
[Re: Stanton]
#2511682
06/22/18 11:44 AM
06/22/18 11:44 AM
Old School
Virginia Beach, VA
I would not use a needle bearing roller lifter for the street. it would be just a matter of time before it fails and sends tool steel shavings throughout your motor. I only use bushed lifters.... Hmmm ... at the Indy Mopar show I asked the Crane rep about using the bushed versus needle bearing lifters on the street. I always figured it would be a better alternative too. He TOTALLY disagreed saying the bushed lifters would not hold up under low rpm use. Part of the reason being that the bushing is solid bronze, not sintered - which couldn't take the beating of a lifter. Therefore it doesn't retain lube and would just burn up. The needle bearing on the other hand would retain some lube in the space between the rollers. As to the OP's question, with a stock, unbushed lifter bore you need a lifter that has the roller wheel shrouded, otherwise it will expose the oil galley at high lift. I don't know about the lifters you're looking at but the Crane 66550 lifter meets the criteria. I use the isky Red Zone EZ Max bushed lifters. They don't use a bronze bushing. I have ruined three of my Street Motors using needle bearing roller lifters. It's never a matter of oiling. The problem is spring pressure. With needle bearings, only two or three of the bearings carry the full load, all the other ones are just along for the ride. It's just a matter of not enough surface area to carry the load......
[Re: Dartski68]
#2511683
06/22/18 11:47 AM
06/22/18 11:47 AM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It would be interesting to know what the ratio is between needle bearing vs bushing, of the roller lifters that have failed on Drag Week.
[Re: Dartski68]
#2511829
06/22/18 05:28 PM
06/22/18 05:28 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
EZ Max bushed lifters. They don't use a bronze bushing. Well do they or don't they ??
[Re: Stanton]
#2511842
06/22/18 05:55 PM
06/22/18 05:55 PM
Old School
Virginia Beach, VA
[quote]EZ Max bushed lifters. They don't use a bronze bushing. Well do they or don't they ?? [/quote They don't call it Bronze. It might have some in it you could call isky to find out......
[Re: Dartski68]
#2511908
06/22/18 09:25 PM
06/22/18 09:25 PM
Posts: 4,213 New York
polyspheric
New York
Just that tiny error in "applications": here is the corrected list High spring pressure High spring pressure High spring pressure High spring pressure High spring pressure High spring pressure High spring pressure High spring pressure High spring pressure High spring pressure High spring pressure High spring pressure High spring pressure
Boffin Emeritus
[Re: Old School]
#2511983
06/22/18 11:54 PM
06/22/18 11:54 PM
Posts: 610 long time lurker, short time p...
PorkyPig
How much spring pressure do you run on the street? How much driving do you do on the street?
[Re: PorkyPig]
#2512096
06/23/18 11:28 AM
06/23/18 11:28 AM
Old School
Virginia Beach, VA
How much spring pressure do you run on the street? How much driving do you do on the street? On mine I am about 260 seat 785 open. I drive only a couple thousand miles a year.....
[Re: Old School]
#2512690
06/24/18 06:44 PM
06/24/18 06:44 PM
BradH
How much spring pressure do you run on the street? How much driving do you do on the street? On mine I am about 260 seat 785 open. I drive only a couple thousand miles a year..... If you need almost 800#s open pressure, you're probably not running a cam that I would consider for a "street motor". No wonder your lifters didn't hold up. Yeah, you drive it on the street, but you're not really building it with any realistic expectations of longer-term durability.
[Re: BradH]
#2512697
06/24/18 07:05 PM
06/24/18 07:05 PM
Old School
Virginia Beach, VA
How much spring pressure do you run on the street? How much driving do you do on the street? On mine I am about 260 seat 785 open. I drive only a couple thousand miles a year..... If you need almost 800#s open pressure, you're probably not running a cam that I would consider for a "street motor". No wonder your lifters didn't hold up. Yeah, you drive it on the street, but you're not really building it with any realistic expectations of longer-term durability. All of that above, is correct....
[Re: Dartski68]
#2512943
06/25/18 11:32 AM
06/25/18 11:32 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
I have Isky Red Zone solid roller lifters 3472-RH in my hemi. They have needle bearings and were bought in 2006. They didn't offer the bushed lifters back then or that's what I would have gotten. I've sent them back for a check-up twice since then, once in '08, last time in '12. Didn't need anything so back in they went. My cam has mild lobes and doesn't need a lot of spring pressure...220# closed, 600# open. I'll be stepping up to a much stronger spring soon, possibly a new cam, and will be sending these lifters back to Isky for yet another check up. I'll evaluate what is needed then.
My KB block has no pressurized lifter oiling. They just get splash and drainback oil. Like said earlier, oiling is rarely the issue w/ lifter failure...it's spring pressure.
[Re: Dartski68]
#2512994
06/25/18 01:09 PM
06/25/18 01:09 PM
an8sec70cuda
Just FYI...Just got an email back from Isky saying my old style needle bearing Red Zone lifters can be converted to solid bushings for less than half the price of a set of new ones.
[Re: Dartski68]
#2513002
06/25/18 01:18 PM
06/25/18 01:18 PM
fast68plymouth
So. Burlington, Vt.
Chip, if you go that route...... get the upgraded “speedway” bushings.
[Re: fast68plymouth]
#2513048
06/25/18 02:47 PM
06/25/18 02:47 PM
an8sec70cuda
Chip, if you go that route...... get the upgraded “speedway” bushings. OK, I was quoted $650 for the EZX upgrade up to 900 psi spring pressure and $720 for the EZMAX upgrade for over 900 psi and/or supercharged/turbo applications.
[Re: Dartski68]
#2513052
06/25/18 02:55 PM
06/25/18 02:55 PM
fast68plymouth
So. Burlington, Vt.
I think the speedway bushings hold up better when you only have splash oiling.
[Re: Dartski68]
#2514406
06/28/18 01:08 PM
06/28/18 01:08 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Last season I rebuilt a set of Comp 869s for the 3rd time.1 lifter had to be replaced with the superceded lifter.Even though the the link bar is at a different height it was not an issue.I have gone upwards of 8k miles on a rebuild which was close to 10k miles.640ish lift with 560 over the nose. 545 inch blown hemi that makes the track 4 or 5 times a year if I'm lucky.
