BB solid roller lifter #2511352
06/21/18 03:24 PM
06/21/18 03:24 PM
Australia
Dartski68 Offline OP
Australia
I have factory lifter bore has anyone used solid roller lifter by crower 66233?
This lifter is available on shelf in Australia so it's my first choice.
I'm also considering comp lifter 96829 or comp amc 861
Solid roller cam duration 263 on intake @ 0.50 with 650 lift, street use with lighter street spring pressure
Re: BB solid roller lifter [Re: Dartski68] #2511391
06/21/18 04:41 PM
06/21/18 04:41 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
I would not use a needle bearing roller lifter for the street. it would be just a matter of time before it fails and sends tool steel shavings throughout your motor. I only use bushed lifters....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: BB solid roller lifter [Re: Old School] #2511487
06/21/18 09:09 PM
06/21/18 09:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been running an Isky solid roller on the street for many years and had the rollers rebuilt once at Isky but when I freshon up my motor, bushings are going back in............Good advice....... beer
Re: BB solid roller lifter [Re: Dartski68] #2511583
06/22/18 01:16 AM
06/22/18 01:16 AM
How man miles, not KM tsk, are you wanting to operate this motor between changing or rebuilding these lifters?
I put around 3000 street miles on a older set of Crower Ultra solid body needle bearing roller lifters with no issues shifting it at or above 7000 RPM at the track, lots of 1/8 and some 1/4 mile passes each year up
Re: BB solid roller lifter [Re: Dartski68] #2511626
06/22/18 08:07 AM
06/22/18 08:07 AM
Australia
Australia
500-1000 miles a year. I will hit the track once a year. The crower available is Not the H hippo oiling version so it only receives splash.
I know some guys ran the comp AMC 848 but it's no longer available and the new part is 861
Re: BB solid roller lifter [Re: Dartski68] #2511675
06/22/18 11:38 AM
06/22/18 11:38 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Hmmm ... at the Indy Mopar show I asked the Crane rep about using the bushed versus needle bearing lifters on the street. I always figured it would be a better alternative too. He TOTALLY disagreed saying the bushed lifters would not hold up under low rpm use. Part of the reason being that the bushing is solid bronze, not sintered - which couldn't take the beating of a lifter. Therefore it doesn't retain lube and would just burn up. The needle bearing on the other hand would retain some lube in the space between the rollers.
As to the OP's question, with a stock, unbushed lifter bore you need a lifter that has the roller wheel shrouded, otherwise it will expose the oil galley at high lift. I don't know about the lifters you're looking at but the Crane 66550 lifter meets the criteria.
Re: BB solid roller lifter [Re: Stanton] #2511682
06/22/18 11:44 AM
06/22/18 11:44 AM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
I use the isky Red Zone EZ Max bushed lifters. They don't use a bronze bushing. I have ruined three of my Street Motors using needle bearing roller lifters. It's never a matter of oiling. The problem is spring pressure. With needle bearings, only two or three of the bearings carry the full load, all the other ones are just along for the ride. It's just a matter of not enough surface area to carry the load......
Re: BB solid roller lifter [Re: Dartski68] #2511683
06/22/18 11:47 AM
06/22/18 11:47 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It would be interesting to know what the ratio is between needle bearing vs bushing, of the roller lifters that have failed on Drag Week.
Re: BB solid roller lifter [Re: Dartski68] #2511829
06/22/18 05:28 PM
06/22/18 05:28 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Well do they or don't they ??
Re: BB solid roller lifter [Re: Stanton] #2511842
06/22/18 05:55 PM
06/22/18 05:55 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
[quote]EZ Max bushed lifters. They don't use a bronze bushing.
[/quote
They don't call it Bronze. It might have some in it you could call isky to find out......
Re: BB solid roller lifter [Re: Dartski68] #2511908
06/22/18 09:25 PM
06/22/18 09:25 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Just that tiny error in "applications": here is the corrected list
High spring pressure
Boffin Emeritus
Re: BB solid roller lifter [Re: Dartski68] #2511923
06/22/18 10:08 PM
06/22/18 10:08 PM
Australia
Australia
Isky needle roller bearing lifter 3672-RH
Has anyone used in stock lifter bore
Im planning to use on a Street solid roller cam with lighter spring pressure
Re: BB solid roller lifter [Re: Old School] #2511983
06/22/18 11:54 PM
06/22/18 11:54 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
How much spring pressure do you run on the street? How much driving do you do on the street?
Re: BB solid roller lifter [Re: Dartski68] #2512030
06/23/18 02:16 AM
06/23/18 02:16 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I have Comp 829's in both of my .660-.690 roller motors. I have an extra set so I send them back to Comp for a check and renew/replace. I have had 1 roller lifter issue in the 16 years I have ran these. Broke the guide bar somehow. shruggy Wiped the cam of course. I needed a bigger one anyway... whistling I swap them out in the race car about 250-300 passes along with the inter. gear. The ones in my Dart were a renew set and have been flawless for about 2 years of beat runs to the store and the occasional car show or something. I would go with the Crowers Dartski68 and not think twice about it.
Re: BB solid roller lifter [Re: Dartski68] #2512046
06/23/18 05:19 AM
06/23/18 05:19 AM
Australia
Australia
Thanks for posts
About 500 miles a year on street
Springs 210 seat & 550 open
Re: BB solid roller lifter [Re: PorkyPig] #2512096
06/23/18 11:28 AM
06/23/18 11:28 AM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
On mine I am about 260 seat 785 open. I drive only a couple thousand miles a year.....
Re: BB solid roller lifter [Re: Old School] #2512690
06/24/18 06:44 PM
06/24/18 06:44 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
If you need almost 800#s open pressure, you're probably not running a cam that I would consider for a "street motor". No wonder your lifters didn't hold up.
Yeah, you drive it on the street, but you're not really building it with any realistic expectations of longer-term durability.
Re: BB solid roller lifter [Re: BradH] #2512697
06/24/18 07:05 PM
06/24/18 07:05 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
All of that above, is correct.... up
Re: BB solid roller lifter [Re: Dartski68] #2512943
06/25/18 11:32 AM
06/25/18 11:32 AM
an8sec70cuda Offline
I have Isky Red Zone solid roller lifters 3472-RH in my hemi. They have needle bearings and were bought in 2006. They didn't offer the bushed lifters back then or that's what I would have gotten. I've sent them back for a check-up twice since then, once in '08, last time in '12. Didn't need anything so back in they went.
My cam has mild lobes and doesn't need a lot of spring pressure...220# closed, 600# open.
I'll be stepping up to a much stronger spring soon, possibly a new cam, and will be sending these lifters back to Isky for yet another check up. I'll evaluate what is needed then.
My KB block has no pressurized lifter oiling. They just get splash and drainback oil. Like said earlier, oiling is rarely the issue w/ lifter failure...it's spring pressure.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: BB solid roller lifter [Re: Old School] #2512962
06/25/18 12:05 PM
06/25/18 12:05 PM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
[/quote]I use the isky Red Zone EZ Max bushed lifters. They don't use a bronze bushing. I have ruined three of my Street Motors using needle bearing roller lifters. It's never a matter of oiling. The problem is spring pressure. With needle bearings, only two or three of the bearings carry the full load, all the other ones are just along for the ride. It's just a matter of not enough surface area to carry the load...... [/quote]
^ this....the same reason I run the same lifters in my combo. Zero issues so far.
