Re: 76,000 yikes
[Re: bigdad]
#2507908
06/13/18 01:52 PM
06/13/18 01:52 PM
Posts: 2,726 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I hate to be the bearer of bad news but I don't think that price includes the turbos/EFI. I think that adds another 30+.
2011 Drag Pak Challenger
Re: 76,000 yikes
[Re: bigdad]
#2507995
06/13/18 04:18 PM
06/13/18 04:18 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
And if you are going to play with the big dogs you have to have spares.
"Just a Bracket car dressed up like a streetcar"
Re: 76,000 yikes
[Re: bigdad]
#2507998
06/13/18 04:33 PM
06/13/18 04:33 PM
Posts: 10,091 MN
JERICOGTX
MN
<<<<<< Checks wallet... Just a little shy. Bummer.
69 GTX
68 Road Runner
Re: 76,000 yikes
[Re: bigdad]
#2508055
06/13/18 06:19 PM
06/13/18 06:19 PM
Posts: 8,637 fredericksburg,va
cudaman1969
fredericksburg,va
I'm guessing those SO engines are in that neighborhood. But at up to 5200 hp you can play. Just ordered 5, now what bank to rob?..
Re: 76,000 yikes
[Re: bigdad]
#2508069
06/13/18 06:41 PM
06/13/18 06:41 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
You know if you just build a good built Hemi with after market parts you'll be into it for $25-30 grand and have 800 --1000 horse power. I see on their web site if you double that cost you can get 5000 horse power. Then the question is , what to do with 5000 horse power. Most can't get under 1000 to hook.
Re: 76,000 yikes
[Re: Stanton]
#2508143
06/13/18 10:00 PM
06/13/18 10:00 PM
Posts: 3,698 jersey
Spaceman Spiff
jersey
This is a normally aspirated motor .... I remember the days when blown fuel motors didn't make that much power !!! it's the basis for a power adder. it's not meant to be run N/A. when you're cramming 60+lbs of boost into it, it has to be able to handle it.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: 76,000 yikes
[Re: bigdad]
#2508212
06/14/18 12:27 AM
06/14/18 12:27 AM
rowin4
After watching the video a number of times , had to watch each gauge , I surprised me he had a G meter. That truck really pulls some G's Also surprised to see a launch of only 3800.
Re: 76,000 yikes
[Re: Spaceman Spiff]
#2508305
06/14/18 10:30 AM
06/14/18 10:30 AM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
This is a normally aspirated motor .... I remember the days when blown fuel motors didn't make that much power !!! it's the basis for a power adder. it's not meant to be run N/A. when you're cramming 60+lbs of boost into it, it has to be able to handle it. Look at the bottom of the ad..."with appropriate power adder". A little over 2k hp is as much as you can get N/A.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
Re: 76,000 yikes
[Re: bigdad]
#2508391
06/14/18 01:57 PM
06/14/18 01:57 PM
Posts: 21,055 in a cattle trailer down by th...
Guitar Jones
I thought bigdad was talking about his post count.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: 76,000 yikes
[Re: bigdad]
#2508397
06/14/18 02:13 PM
06/14/18 02:13 PM
Guitar Jones
But you're not a quitter!
