Page 4 of 5 1 2 3 4 5
Re: Inexpensive AN fittings [Re: mopar dave] #2504428
06/04/18 04:54 PM
06/04/18 04:54 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
At my prior employer when we did the turbo challenger the engineer in charge of it was adamant on using Jegs house brand stuff in black so that's what we did. He disliked the appearance of red/blue. I was against it at first but it wasn't my decision, and after working with it a little bit, it seemed pretty decent. If I wanted cheaper stuff that's probably where I'd look. All I have used on my own garbage is Aeroquip products.
Rich H.
Esse Quam Videri
Re: Inexpensive AN fittings [Re: rowin4] #2504445
06/04/18 05:40 PM
06/04/18 05:40 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
LOL. Didnt know that.
Re: Inexpensive AN fittings [Re: Pacnorthcuda] #2504447
06/04/18 05:41 PM
06/04/18 05:41 PM
Mt Morris Michigan
Mt Morris Michigan
I remember it well. Called it Japanese junk.
Re: Inexpensive AN fittings [Re: mopar dave] #2504507
06/04/18 08:46 PM
06/04/18 08:46 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have been buying Fragola fittings for my latest fuel system plumbing project and I was impressed at the fit and no leaks.
I saved some money on the fittings but they fit and worked as well as the Aeroquip fittings I have at the rear of the car.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Inexpensive AN fittings [Re: fourgearsavoy] #2504511
06/04/18 09:06 PM
06/04/18 09:06 PM
Mt Morris Michigan
Mt Morris Michigan
I have earls and russel on my car. Been on there for a long time and no leaks yet.
Re: Inexpensive AN fittings [Re: mopar dave] #2504516
06/04/18 09:29 PM
06/04/18 09:29 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
For the past 4 years I have been buying all my hose and fittings from a place called "Getfast1"
Excellent pricing and no issues, the last batch of fitting were Fragola.
Re: Inexpensive AN fittings [Re: RV2] #2504522
06/04/18 09:32 PM
06/04/18 09:32 PM
Mt Morris Michigan
Mt Morris Michigan
They currently have fittings listed on Ebay.
Re: Inexpensive AN fittings [Re: ZIPPY] #2504550
06/04/18 10:56 PM
06/04/18 10:56 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
on my car 95% of the fittings and braided hose including pre made stainless brake lines is Jegs house brand, been using their stuff foe years and will keep on using their stuff.
Re: Inexpensive AN fittings [Re: mopar dave] #2504638
06/05/18 01:44 AM
06/05/18 01:44 AM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
Having some first hand experience in the hyd hose and fitting world in both the industrial and aerospace markets I would say that there is not much difference between the cheap fittings and the high dollar Aeroquip types. Except for true AN or MS spec'd fittings. Nothing industrial is ever qualified for use in the air.
There is a good read on Air-Way's website providing a brief history of the AN to JIC fitting.
https://www.air-way.com/news/whats-the-d...-air-way-fit-in
Most of the companies in the states are using mfg sources with screw machines set up to pump out straight fittings (hose ends and adapters). Forged shapes come from companies such as Brennan Industries and are then machined at centers to be finished off. Hex bar stock (cold rolled or aluminum) can come from anywhere and fed into the screw machines in the states to be "Made in USA". The brand/mfg stamp is struck on the bar stock before machining. A single screw machine could pump out several mfg's parts just by changing the feed.
Take a look at the Earls site and even Fragola and look at the carbon forged shape pics. There is a BI stamped on the body. That is Brennan Industries. Based on the info on Fragola's site they run their own screw machines and possible cnc centers (for forged shape machining).
Companies such as Parker and Aeroquip have or had production plants in Cleveland, Maumee, and Van Wert OH and pumped out fittings for OEM, Aerospace, and Industrials. That may have changed since I left the hose mkt, but that was back in the early 2000's.
And for pricing on AN fittings...the supply chain group I was a part of supplied true AN/MS fittings to the Gov't and even Stratoflex for fractions of what they are going for on some of the aircraft supply sites.
And one hex past finger tight is all it should take to seal up a 37deg union.
Re: Inexpensive AN fittings [Re: mopar dave] #2504885
06/05/18 04:23 PM
06/05/18 04:23 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
There are many things, some very common and simple, easily available to the public and cheap, that once they are certified for and allowed in aircraft facilities, take on new names, part numbers and costs.
Likewise, there are few things that have not been copied appearance wise and dumbed way down quality wise in the far east for an American market that wants their fancy stuff without paying the price.
Re: Inexpensive AN fittings [Re: mopar dave] #2614672
01/30/19 06:05 PM
01/30/19 06:05 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I want to revisit this because I recently had a little experience with Summit house brand fittings vs Fragola on some #12 line I was putting together, and can give somewhat of a review.
The Summit house brand fittings went together easier than any I have ever seen. They have...I won't call it threaded, but more of a spiral in the area the hose is put into that allows you to very easily twist the hose in place.
Like Aeroquip, Fragola does not have this spiral inside, and the hose has to be very forcibly pushed into place before the end is assembled/it fits very tightly.
During assembly, the Fragola puts up much more of a fight and noticeably crushes the hose similar to the Aeroquip products I have used in the past. The Summit brand does not noticeably crush the hose very much at all, and it goes together very easily. Summit brand does pass a pull test.
In the end, I believed the Fragola to be slightly more trustworthy due to the manner it crushed the hose...and ended up returning the Summit house brand.
The "spiral" inside the summit brand hose ends did seem like a good idea, and did speed up assembly a little. The anodizing was just as good.
I don't make 800 hoses a day or anything, if you do then you'd probably find my post ridiculous...if you're like me and only do a few here and there, maybe this post will help a little........
Rich H.
Esse Quam Videri
Re: Inexpensive AN fittings [Re: ZIPPY] #2614697
01/30/19 06:51 PM
01/30/19 06:51 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I have used primarily (90%) Jegs housebrand and they are like the summit brand with the threading, very easy to assemble and not one failure. up
Re: Inexpensive AN fittings [Re: mopar dave] #2614706
01/30/19 07:13 PM
01/30/19 07:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
All of the good stuff I've used requires some force or effort to get it together. I've never used any of the cheap stuff, but I would be wary of "easy". Long ago when I started paying attention to the ID of the hardware vs. the hose itself, was when I really started to pay attention to what I was getting.
Re: Inexpensive AN fittings [Re: theraif] #2614725
01/30/19 07:51 PM
01/30/19 07:51 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Originally Posted By theraif
stirthepot
I love tim!
Racing cost money Son, How fast do you want to go?
The painfull lesson of using cheap parts will catch up to everybody.
AN stand for Army/Navy so you know that was not built to be cheep.
Re: Inexpensive AN fittings [Re: mopar dave] #2614747
01/30/19 08:58 PM
01/30/19 08:58 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I cheaped out and tried JEGS,,,,,,,,,,,,,,once!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Inexpensive AN fittings [Re: mopar dave] #2614794
01/30/19 10:28 PM
01/30/19 10:28 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I use mainly for fragola and XRP but use many Earl's and Aeroquip also. I literally have 1000's still laeft over after plumbing probaly over 35 of mine & my buddies cars over the years. These don't include any of the black hose & fittings that I now use for my car only.
20160312_200339.jpg20160312_200516 (002).jpg20160312_195742.jpg20160312_195913 (002).jpg
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Inexpensive AN fittings [Re: mopar dave] #2614840
01/31/19 12:09 AM
01/31/19 12:09 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
We tend to use Phenix Industries fittings. I've never had a problem with any of their fittings on multiple builds, I get dealer pricing, and the entire inventory is right down the street from my parent's house. Convenience is the key in my case, but they offer a pretty decent piece at a very fair price.
Phenix Industries
Re: Inexpensive AN fittings [Re: mopar dave] #2614991
01/31/19 12:42 PM
01/31/19 12:42 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The problem I have with Jeg's fittings is the price is often the same as Aeroquip.
2011 Drag Pak Challenger
Re: Inexpensive AN fittings [Re: mopar dave] #2615096
01/31/19 03:11 PM
01/31/19 03:11 PM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
Fragola & Earls only for me.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Inexpensive AN fittings [Re: mopar dave] #2615100
01/31/19 03:14 PM
01/31/19 03:14 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We have lots of Fragola and some Summit house brand on the Daytona. Both seem to be quality and made in the USA.
