Ebody offset hangers and super stock springs #2504806
06/05/18 01:49 PM
06/05/18 01:49 PM
Chester, VA
tobnHisglory Offline OP
Chester, VA
I purchased mopar offset hangers and offset shackles for a 73 Cuda. I installed them with mopar super stock springs which I was under the impression was a matching system. Now my set up is 2 inches or so too short. Everything bolts up but the rear shackles are all the way forward and the rear spring eye is touching the bottom of the frame rail.
My question is, did I buy the wrong offset hangers? Is there an extended offset hanger for superstock springs on an ebody? Does anyone know the part number if so?
Thanks,
Reggie
-Reggie
tobnHisglory2000@aol.com
Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4
Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
Re: Ebody offset hangers and super stock springs [Re: tobnHisglory] #2504818
06/05/18 02:14 PM
06/05/18 02:14 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Did your SS springs come with a front relocated perch (yes you have the inboard relocation, but is it for SS spring use?, IIRC the E body SS spring application requires a new front relocated perch, because the springs are short and the relocated perch moves the spring rear ward (springs are originally designed for A body application)...
Re: Ebody offset hangers and super stock springs [Re: tobnHisglory] #2504844
06/05/18 03:00 PM
06/05/18 03:00 PM
MA
K
Kevin Kowalski Offline
K
MA
MP super stock springs have A-body dimensions. The front half of super stock springs is 20 inches long, which is 2 inches shorter than a stock E-body spring. MP sells 2 inch longer extended offset front hangers to use with the shorter springs. If the offset hangers you have are short like the originals, that's your problem.
Kevin
Re: Ebody offset hangers and super stock springs [Re: Kevin Kowalski] #2504868
06/05/18 03:52 PM
06/05/18 03:52 PM
Chester, VA
Chester, VA
That was my assumption but I can't find a part number for the longer front offset hangers. I thought that is what I bought but they aren't long enough. Anyone have a part number?
-Reggie
Re: Ebody offset hangers and super stock springs [Re: tobnHisglory] #2504930
06/05/18 06:52 PM
06/05/18 06:52 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thanks,
Reggie
The best I can do for you is the following, as I don't know exactly what your trying to accomplish?
IF you want to run the SS springs AND also OFF SET hangers to move the springs inboard you need MP kit# 4120078 for the front spring perches and MP kit# 4120076 for the rear shackles, IF you are running the stock WIDTH E body rear axle?, you'll need to remove and relocate/reweld the AXLE perches INBOARD on the axle, OR install a STOCK WIDTH 67-70 B-Body rear end as that will BOLT-IN on the relocated front spring perches and offset rear shackles
IF you want to keep the E body STOCK WIDTH rear end, with no mods to the AXLE perches AND use the SS SPRINGS, you'll need MP front perch kit# P4120080 and you'll use the stock E body rear shackles...
Would be nice to know what kind of "offset" your looking for?, positive or negative regarding the back spacing of the intended tires/rims
FYI, I don't know if the MP PN#s are still available, or superseded?... DrDiff.com offers a lot of spring and axle options/parts that would probably be your best source for better quality parts to accomplish your SS spring install to the criteria you desire...
Hope this helps?
Mike
Re: Ebody offset hangers and super stock springs [Re: DAYCLONA] #2504997
06/05/18 10:15 PM
06/05/18 10:15 PM
Chester, VA
Chester, VA
Thank you. I have a 67 b body rear and want the offset and to use the ss springs. I got offset perches and shackles and ss springs, the perches just weren't extended like I thought I was buying. Thanks for the part numbers.
-Reggie
Re: Ebody offset hangers and super stock springs [Re: DAYCLONA] #2505000
06/05/18 10:23 PM
06/05/18 10:23 PM
Chester, VA
Chester, VA
Actually I just checked and that is the offset perches I already have. They are the standard length for regular springs not the shorter super stock springs. I'll check what Dr Diff offers. Thanks again.
-Reggie
Re: Ebody offset hangers and super stock springs [Re: tobnHisglory] #2505038
06/06/18 12:05 AM
06/06/18 12:05 AM
Richmond Twp. Mi.
Mr340 Online content
Mr340  Online Content
Richmond Twp. Mi.
you could put a 2"spacer behind the perches, 2x3 or 2x4 3/16 or 1/4"wall tubing.
these have the hole pattern offset, since you have the offset hangers your hole pattern would be inline.
Re: Ebody offset hangers and super stock springs [Re: tobnHisglory] #2505156
06/06/18 11:51 AM
06/06/18 11:51 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Bolt in offset spring hangers for SS springs do not exist. You can choose 1" offset for stock length springs or standard location SS spring hangers.
The 3" relocation kit will accomodate SS springs, as they weld into the frame rail.
IMO, use the 1" offset kit. Mount your stock length main leaf, re-drill and re-stack your SS leafs under the original main leaf without using the SS main leaf. #2 SS leaf tip should center under the front eye of the main spring, and then everything else stacks under it as aligned like the SS pack orientation. That way you get the offset, a longer main leaf, and SS spring action. This is an old class racer trick outlined in the Mopar Suspension Manual for cars that are required to maintain original mounting locations. Its well established and proven effective.
