Did your SS springs come with a front relocated perch (yes you have the inboard relocation, but is it for SS spring use?, IIRC the E body SS spring application requires a new front relocated perch, because the springs are short and the relocated perch moves the spring rear ward (springs are originally designed for A body application)...
