Opinions on engine combo and power output
#2503649
06/02/18 06:06 PM
06/02/18 06:06 PM
Posts: 27 AB
Pockets
AB
Just finishing putting together a 440RB stroker. Wondering what power numbers it should make, and opinions on the combo. It's going in a Ramcharger for mud racing/off roading/play truck. 44" tires, 5.38 gears.
Also what would be suggested for a converter, 727 trans. Do not want the converter to slip when driving down the highway at 60-70 mph. Have been considering Hughes 24-25HD 11" 2500 stall.
493 cu in. 440 RB block Milodon pan JE 232452 inverted dome piston, 4.35" bore 4.15" stroke, 6.76" rod Fel pro 1009 head gasket .039" compressed zero deck, .039" squish 9.5:1 compression Edelbrock 60929 84cc heads out of the box Howards solid roller 722113-08 277/285, 245/253 @ .050", 108 LSA installed at 104 ICL to cam card specs. .640"/.640" lift with 1.6 rocker, .022/.022" lash Comp AMC lifters 861-16, 829-L link bars Harland Sharp S70016KE 1.6 rockers, Hughes hold down kit Smith Bros 5/16"x .116" wall pushrods, through pushrod oiling .040" oil restricted Performer RPM intake with 1" open spacer Mark Whitener 4150 1050 carb with annular boosters Straight up derby style headers, 2"x28" primaries, 4"x12" collectors. May add additional length to the collectors.
Thanks guys!
Re: Opinions on engine combo and power output
[Re: Pockets]
#2503652
06/02/18 06:22 PM
06/02/18 06:22 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
That's not to far from my build as mine is a 440/493. You have more cam as I run a solid flat tappet that's 264 & 270 @ .050 with .585 & .592 lift and a 110 LSA and I use Hughes 1.6 rockers and Manton pushrods. I have a bit more comp at 10.6 and I use the basic SEZ head which is about like your heads. I use the Indy dual plane intake and a Holley 850 DP. I never dyno's mine but my 63 has run 10.70's at over 3700 lbs. It seems to come out around 600 hp on some charts at the flywheel. I would guess your build in the 575 to 625 hp range at the flywheel. Good luck , Ron
[Re: Pockets]
#2503691
06/02/18 09:08 PM
06/02/18 09:08 PM
Posts: 2,867 Pattison Texas
CSK
Pattison Texas
540 HP, I would not use the 1009 gaskets, get some Cometic head gaskets
[Re: Pockets]
#2503786
06/03/18 03:27 AM
06/03/18 03:27 AM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
A few 493 we have put together have not had issues using the 1009 gaskets. Is there a known issue we haven’t experienced yet? I am kind of wondering the deal here ? The 1009 is listed as 4.410 bore . Unless you have a big champher at top of bore what issue can you have ? I have used 4.410 bore cometics in my 440 and 505 , 440 was at 0.055 over I have fitted 1009 with my Trickflows , and trickflow recommend this gasket . Trickflow also say their head will not fit under a 4.320 bore Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2503854
06/03/18 12:11 PM
06/03/18 12:11 PM
Posts: 277 MN
Willie68coronet
MN
A few 493 we have put together have not had issues using the 1009 gaskets. Is there a known issue we haven’t experienced yet? The 1009 is listed as 4.410 bore . Unless you have a big champher at top of bore what issue can you have ? Tex Yep. I was gonna use a 1009 since it fit my Indy ez heads but laying them on my '77 440 block. it overhung the bore chamfer but didn't on my back up '72 440 block. So it depends
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: Pockets]
#2503881
06/03/18 01:03 PM
06/03/18 01:03 PM
Posts: 12,210 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Before you pull the trigger on the converter, you might want to talk to a converter builder or two and get their input. With the torque you will be making, it could be a challenge to get one tight enough. And make sure that they are clear with you on how their converters will act in your vehicle. Have them review in detail flash, stall, etc. There might be an off-the-shelf converter for you, but it would be a good idea to talk to the converter guys.
Personally, I have used PTC for many years with good results. But my last couple of converters from them missed the mark and they were too busy to spend much time working it out. Called Lenny at Ultimate. He spent the time to get the info and then re-worked the PTC to my satisfaction.
Master, again and still
[Re: DaveRS23]
#2503923
06/03/18 02:46 PM
06/03/18 02:46 PM
Posts: 27 AB
Pockets
AB
Personally, I have used PTC for many years with good results. But my last couple of converters from them missed the mark and they were too busy to spend much time working it out. Called Lenny at Ultimate. He spent the time to get the info and then re-worked the PTC to my satisfaction. Hughes recommended their 24-30HD 3000 stall. But the tech reply did not really make sense to me. Seemed opposite to how I was thinking how the choice was to be made. What do you think of what he said? I did give all the vehicle specs, and said we want to be sure the converter won’t be slipping driving at 60-70 mph, because we have ran into that issue before. “Thank you for the tech card and no I can get you into a 2500 stall with this combo. The tightest you can go is a 3000 stall model. Even if a 2500 stall might allow the engine to remain running with out stalling, once you drop it into low range on the transfer case it would be way to tight for playing in the mud. For mud racing racing you need the complete opposite to keep engine RPM up. 24-30HD is a 3000 stall” “Thank you, and there is always a chance of additional heat, just run a good cooler in the bed with a fan and that should handle the issue if it is a problem. I have people running much higher stalls on the street that can maintain 180-190 with no issues. Correct stalls actual can produce less heat if its not fighting the engine being too tight.”
[Re: Pockets]
#2504123
06/03/18 11:26 PM
06/03/18 11:26 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
For our vehicles, converter selection is as important (and sometimes) as difficult as cam selection. Which is compounded by a lack of particular cores. I have been through this a couple of times now.
If you want a loose converter...no problem. But if you want a fairly tight streetable converter for our BB stroker motors......that is a real challenge.
I would like to have a tighter converter in my Cuda, but the cores just aren't available to get there.
You know your combo. Now think about what you want the converter to do and call some converter builders with your specs and preferences. The reputable converter guys will tell you what is and what isn't possible.
[Re: Sport440]
#2504156
06/04/18 12:42 AM
06/04/18 12:42 AM
383man
Balt. Md
Your going to want some stall with your mud bogging intentions. A quality vert will stall where you need and provide very little slippage at highway speeds. My vote a 9.5" 3800 stall Dynamic, or something similer from ati or so. I would not go Less then that with your overall intended combo. If you do, you would be leaving performance on the table. I agree as I run a Dynamic 9.5 in my 63 and in my sons Dart. And we both love them as its their street/strip converters that drive great and work nice at the track. Mine is rated at a 4200 flash but I can cruise at 2500 to 3200 rpm all day long with no slippage or heat buildup. I love it as its been in my 63 since 2006 and still going strong and my 63 is a 99% street car. Ron
[Re: Pockets]
#2504836
06/05/18 02:43 PM
06/05/18 02:43 PM
Posts: 5,164 CT
GTX MATT
CT
563 HP 607 ft lbs
