Relocate TDC mark and timing tape - SBM #2503700
06/02/18 09:30 PM
06/02/18 09:30 PM
New Mexico
Adobedude Offline OP
New Mexico
With my low mount alternator it's close to impossible to see the TDC mark and the timing tape on the balancer, can I make a new TDC mark and relocate a new timing tape where I can see it?
Sorry if it's a stupid question. shruggy work
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Relocate TDC mark and timing tape - SBM [Re: Adobedude] #2503707
06/02/18 10:23 PM
06/02/18 10:23 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Index it where ever you want once you get TDC,I used a paint pen to mark balancer and timing cover where you want.
Re: Relocate TDC mark and timing tape - SBM [Re: Adobedude] #2503711
06/02/18 10:50 PM
06/02/18 10:50 PM
there are no stupid questions & your inquiry is a real good question. Yes it wouldn't hurt to confirm TDC & you can get SB timing covers with the marks on either side and or buy the bolt on pass side bolt on timing tab & I see em on FABO regularly or as said make a new pointer or tab & a white paint mark on the dampener (clean that area first with brake kleen) then roll on your tape then seal it to the dampener with spray clear lacquer so it will stay put & not fly off.
Re: Relocate TDC mark and timing tape - SBM [Re: Adobedude] #2503714
06/02/18 10:57 PM
06/02/18 10:57 PM
New Mexico
New Mexico
Sweet....
Thanks guys.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Relocate TDC mark and timing tape - SBM [Re: Adobedude] #2503723
06/02/18 11:17 PM
06/02/18 11:17 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Never trust old marks or dampers, I just done the piston stop in plug hole trick with 2 of our engines, both were out. With stop in wind clock wise to stop and mark, wind counter clock wise to stop and mark, then the exact middle of marks is TDC .
1963 Plymouth Max Wedge
1971 Barracuda
Re: Relocate TDC mark and timing tape - SBM [Re: Adobedude] #2503724
06/02/18 11:18 PM
06/02/18 11:18 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I hope I did this ^^ right smile
1971 Barracuda
Re: Relocate TDC mark and timing tape - SBM [Re: ozymaxwedge] #2503735
06/02/18 11:44 PM
06/02/18 11:44 PM
New Mexico
New Mexico
X2...That's the way I do it.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Relocate TDC mark and timing tape - SBM [Re: Adobedude] #2503773
06/03/18 02:09 AM
06/03/18 02:09 AM
I turn the dampener to 15BTDC on the tab then screw in the stop till it touches the piston then go back CCW & see if it stops at exactly 15 ATDC on the tab.
