Re: Relocate TDC mark and timing tape - SBM
[Re: Adobedude]
#2503707
06/02/18 10:23 PM
06/02/18 10:23 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Index it where ever you want once you get TDC,I used a paint pen to mark balancer and timing cover where you want.
[Re: Adobedude]
#2503711
06/02/18 10:50 PM
06/02/18 10:50 PM
RapidRobert
there are no stupid questions & your inquiry is a real good question. Yes it wouldn't hurt to confirm TDC & you can get SB timing covers with the marks on either side and or buy the bolt on pass side bolt on timing tab & I see em on FABO regularly or as said make a new pointer or tab & a white paint mark on the dampener (clean that area first with brake kleen) then roll on your tape then seal it to the dampener with spray clear lacquer so it will stay put & not fly off.
[Re: Adobedude]
#2503723
06/02/18 11:17 PM
06/02/18 11:17 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Never trust old marks or dampers, I just done the piston stop in plug hole trick with 2 of our engines, both were out. With stop in wind clock wise to stop and mark, wind counter clock wise to stop and mark, then the exact middle of marks is TDC .
1963 Plymouth Max Wedge 1971 Barracuda
[Re: ozymaxwedge]
#2503735
06/02/18 11:44 PM
06/02/18 11:44 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I hope I did this ^^ right X2...That's the way I do it.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#2503773
06/03/18 02:09 AM
06/03/18 02:09 AM
RapidRobert
I turn the dampener to 15BTDC on the tab then screw in the stop till it touches the piston then go back CCW & see if it stops at exactly 15 ATDC on the tab.
