Trim Rings for 15 X 8 Rallye Wheels #2501738
05/29/18 01:56 PM
05/29/18 01:56 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
Are there trim rings available that fit a 15 X 8 Rallye wheel, or do I have to live with an inch of gap with a 15 X 7 ?
Mopar
Or
No
Car
Re: Trim Rings for 15 X 8 Rallye Wheels [Re: MONC] #2501749
05/29/18 02:20 PM
05/29/18 02:20 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You have to live with the "gap", it's actually not that bad, I've already been thru trying the 15x8 GM trim rings and other aftermarket 15X8 rings they won't even fit
Re: Trim Rings for 15 X 8 Rallye Wheels [Re: MONC] #2501754
05/29/18 02:31 PM
05/29/18 02:31 PM
MONC Offline OP
MONC  Offline OP
Appreciate the insights Mike, saves me some time.
Figured if anyone would know you would wink
Bummer though.. frown
Mopar
Or
No
Car
Re: Trim Rings for 15 X 8 Rallye Wheels [Re: MONC] #2501768
05/29/18 03:04 PM
05/29/18 03:04 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I was just looking through the brushed trim ring options this weekend: Jeg's and Coker both list various trim rings for 7, 8 & 10" sizes, and some say OEM wheels or Aftermarket wheels only.
In my case for Magnum wheels.
Not much to go on; or should I say lots of info but none of it conclusive.
Re: Trim Rings for 15 X 8 Rallye Wheels [Re: MONC] #2501769
05/29/18 03:12 PM
05/29/18 03:12 PM
MONC Offline OP
MONC  Offline OP
Yeah, looked at Jeg's and Coker as well this morning, really didn't see anything definitive..
Mopar
Or
No
Car
Re: Trim Rings for 15 X 8 Rallye Wheels [Re: MONC] #2501801
05/29/18 04:06 PM
05/29/18 04:06 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
A little more drastic work-around...
You could run 5 1/4” backspacing and run a 1” spacer or a 2” overall wider rear end.
Wheel will look like a 15x7 from the side.
Re: Trim Rings for 15 X 8 Rallye Wheels [Re: MONC] #2501879
05/29/18 05:40 PM
05/29/18 05:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Yeah, I've bought 15X8 trim rings from Jegs, Wheel Vintiques, even JC Whitney! and a few other sources that looked promising for a factory looking trim ring, some were real nice, they just didn't fit on the rim....here's the factory 15X7 ring on Wheel Vintiques 15X8
Re: Trim Rings for 15 X 8 Rallye Wheels [Re: DAYCLONA] #2502014
05/29/18 11:18 PM
05/29/18 11:18 PM
Washougal,Wa
Dodge Offline
Dodge  Offline
Washougal,Wa
Man, im not a fan of the gap. I always get rid of 14in rallye rims and the 8in wide 15s. Not sure id even like 8s if the trim ring fit. My friends say im a little different, lol.
Stand behind your word
Re: Trim Rings for 15 X 8 Rallye Wheels [Re: MONC] #2502082
05/30/18 02:13 AM
05/30/18 02:13 AM
A collage of whims
A collage of whims
I'd like to see a photo of that on a 69-up-style 15x8 Magnum wheel; I'm thinking about 15x8s on a '69 B-body. Not sure if they'd hide the outer part of the recessed areas. Many years back, I ran something like the Vette rings on 15x8 Rallyes on a '70 Barracuda, but obviously they're not brushed. Further back than that, I put 14x7 Magnums with Ford 14x7 brushed trim rings on a '69 Road Runner and it fooled pretty much everybody. Those rings were discontinued years ago, and I'm kinda hung up on stock-appearing 15x8s for those cars now. I'd prefer to avoid the '67-'68 full chrome Magnums on '69-up cars, and I didn't have good luck with the trim rings staying on the chrome barrels back in the 14x7 days.
The 15x8 Magnum wheels with painted barrels ('68-up style) are available from Coker, but they're vague on the trim rings.
Re: Trim Rings for 15 X 8 Rallye Wheels [Re: topside] #2502245
05/30/18 02:28 PM
05/30/18 02:28 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
I use the 15x6.5 trim rings on my front 15x7 wheels and the 15x7 trim rings on my 15x8 rear wheels at least the gap is the same
NS1AAR
Re: Trim Rings for 15 X 8 Rallye Wheels [Re: ns1aar] #2505768
06/07/18 11:33 PM
06/07/18 11:33 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
what is the best bang for the buck on decent rings these days? I just ordered wheels from summit (7s and 8s) but not sure which rings to get,here are some on ebay:
https://www.ebay.com/itm/Mopar-Mopar-dod...15/173351060265
https://www.ebay.com/itm/15-x-7-Olds-Cut...le/263730865167
https://www.ebay.com/itm/4-Pc-Set-CHEVY-...in/390457717855
Re: Trim Rings for 15 X 8 Rallye Wheels [Re: autoxcuda] #2505949
06/08/18 02:57 PM
06/08/18 02:57 PM
MA
K
Kevin Kowalski Offline
K
MA
That's what I did. I ordered 15x8 rallyes from Stockton Wheel in CA with 1" more backspacing than a stock 15x7. IIRC it was 5-1/4" like autoxcuda stated. I also moved my springs inboard about 3/4" per side for clearance. This gave the correct fit for the trim ring with no gap and the outside of the tire and wheel are in the stock location with a stock width rear housing.
Re: Trim Rings for 15 X 8 Rallye Wheels [Re: MONC] #2506126
06/09/18 12:38 AM
06/09/18 12:38 AM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Keep thinking somebody has to make 3 or 3.5 inch rings. And There has to be a way to attach mopar mounting springs salvaged from ratty old rings.
Re: Trim Rings for 15 X 8 Rallye Wheels [Re: DAYCLONA] #2507596
06/12/18 05:51 PM
06/12/18 05:51 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I used the polished Wheel Vintiques 15x7 trim rings on a set of 8" wheels stretched by Stockton Wheel back in the day. They look identical. You don't get ugly until you go to a 10" stretch. Those look darn ugly.
I’m listening.
