Backyard freshing up a race motor on the cheap #250139
03/10/09 10:01 PM
03/10/09 10:01 PM
jax. fla.
70Dustmite440 Offline OP
jax. fla.
So i dug my old 451 out and tore it down to see whats up.
Its going to need one piston (ross dome) due to the smallest of pinched ring land, rings and a hone job.
Question, do i need to haul it down to the machine shop for a torque plate hone or can i achieve good ring seal with an at home hone job? the motor had about 100 or less passes about 1/2 with heavy nitrous so the rings just gave out.
If i fire it up and it huffs and puffs like a cho-cho train I'll be pissed, but i don't have any money to waste ether.
all opinions accepted, thanks.
8sec. street car, been there done that. Quitting when your ahead isn't the same as quitting.
[img]https://scontent-atl.xx.fbcdn.net/hphoto...amp;oe=55DB3E4C[/img]
https://www.facebook.com/eric.norton.1048
R.I.P.UN.
Re: Backyard freshing up a race motor on the cheap [Re: 70Dustmite440] #250140
03/10/09 10:04 PM
03/10/09 10:04 PM
Q
Quicktree Offline
Quicktree  Offline
Q
for the cost of a hone job it's not worth the risk imo. also depends on what you intend to do with it? more juice?
Re: Backyard freshing up a race motor on the cheap [Re: 70Dustmite440] #250141
03/10/09 10:05 PM
03/10/09 10:05 PM
jax. fla.
jax. fla.
I should add it was originally filled, and bored then honed with a plate and was one of the best sealed up motors evar!
Re: Backyard freshing up a race motor on the cheap [Re: Quicktree] #250142
03/10/09 10:07 PM
03/10/09 10:07 PM
jax. fla.
jax. fla.
Hi Tony, it will see as much nitros as can flow through a 906 head and that aint much.
Re: Backyard freshing up a race motor on the cheap [Re: 70Dustmite440] #250143
03/10/09 10:10 PM
03/10/09 10:10 PM
Q
Quicktree Offline
Quicktree  Offline
Q
it would probably run with out the hone but I would hone it
Re: Backyard freshing up a race motor on the cheap [Re: Quicktree] #250144
03/10/09 10:13 PM
03/10/09 10:13 PM
jax. fla.
jax. fla.
I'm quite sure you right, the plan was to have the guys around the corner from me hone it. As far as i know their the only guys in town w/ a plate and they did a super job for me last time!
Then the bottle brush thread got me thinking....
Re: Backyard freshing up a race motor on the cheap [Re: Quicktree] #250145
03/10/09 10:13 PM
03/10/09 10:13 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
Are you gonna screw the Duster back together?
Re: Backyard freshing up a race motor on the cheap [Re: 70Dustmite440] #250146
03/10/09 10:15 PM
03/10/09 10:15 PM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
If you want it to last, why be cheap? Kind of like being married, then get a divorce for some bullshot.
Engine by DeTar http://www.kansasbadman.com
Re: Backyard freshing up a race motor on the cheap [Re: Dart1031] #250147
03/10/09 10:16 PM
03/10/09 10:16 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
didnt you have indy sr,s and B1 heads
good to see you will put the car together again
1.39 9.85 - 137 mph
Re: Backyard freshing up a race motor on the cheap [Re: Dart1031] #250148
03/10/09 10:18 PM
03/10/09 10:18 PM
jax. fla.
jax. fla.
I'm working on it, money is non existent... but i don't need to much to have it create an even larger carbon footprint than i already have going.
It wont be fast tho. Mid 9's i suppose
R.I.P.UN.
Re: Backyard freshing up a race motor on the cheap [Re: CH3NO2] #250149
03/10/09 10:21 PM
03/10/09 10:21 PM
jax. fla.
jax. fla.
You've been reading from my hand book i see.
Re: Backyard freshing up a race motor on the cheap [Re: Ari440] #250150
03/10/09 10:24 PM
03/10/09 10:24 PM
jax. fla.
jax. fla.
Yep had them all, sold them all....
Now i'm stuck w/ 906's and plan to run 5's at 3200lb in the 1/8th.
