airgrabber #2497306
05/17/18 06:41 PM
05/17/18 06:41 PM
mass
raybee Offline OP
raybee  Offline OP
mass
Hi having trouble with my air grabber setup on 1970 roadrunner only opens when you help it by hand could it be the canister or something i overlooked
Re: airgrabber [Re: raybee] #2497360
05/17/18 09:19 PM
05/17/18 09:19 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Run a test vacuum hose direct from the vacuum fitting on the intake manifold, to the door actuator itself, and then see how well it opens, eliminating the switch, and vacuum canister, and all the hoses.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: airgrabber [Re: raybee] #2497571
05/18/18 03:12 PM
05/18/18 03:12 PM
Chicago
PurpleBeeper Offline
Chicago
Hemi71x has a good point. It opens by vacuum, so start measuring you vacuum at the hoses & move back towards the switch. Switches often leak, fyi.....hoses can leak, canister can leak, actuator can leak.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
