dana 60 #2495197
05/12/18 06:23 PM
05/12/18 06:23 PM
br67 Offline OP
br67  Offline OP
will a 354 gear fit in a carrier that has 410 gears the rear end is a 1970 dana 60
Re: dana 60 [Re: br67] #2495262
05/12/18 09:11 PM
05/12/18 09:11 PM
Yes sir it will up
3.54,3.73, 3.91 and 4.10 gears will all fit on the early 3 series carriers, posi and opened up
Re: dana 60 [Re: Cab_Burge] #2495408
05/13/18 08:37 AM
05/13/18 08:37 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Originally Posted By Cab_Burge
Yes sir it will up
What about 4.88s? I have an Ultimate Dana 60 that currently has 4.10 gears & I have a contact who will swap his 4.88s for my 4.10s. Are they going to fit?
Re: dana 60 [Re: rebel] #2495443
05/13/18 10:52 AM
05/13/18 10:52 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
To the best of my knowledge no...
There are spacers available but not recommended for manual shift or high horsepower applications.
However the 4.10 is not going to work in your friends car either unless you swapped carriers as well as gears.
Re: dana 60 [Re: 340Cuda] #2495548
05/13/18 02:48 PM
05/13/18 02:48 PM
iagree
Most 3 series carriers or spools are from 3.54 to 4.10 and the 4 series are from 4.56 to 5.38. Some after market 4.30 ratio gear will fit either one as long as you order the proper part number for your carrier shruggy
Dana Corp. use to only make one offset on the all of their Dana 60 ring gears so you had to change carriers to switch to the lower gears, Dana started making Dana 60 gears for both series some time in the mid 1990s is what I have heard recently shruggy
How to tell which part number for which carrier is the hard part confused
All the Dana 70 I've worked on are that way so you can order any ratio for any year Dana 70 carrier up
Re: dana 60 [Re: 340Cuda] #2495568
05/13/18 03:46 PM
05/13/18 03:46 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have used a spacer in the past with no problem , just use on lock tight on the bolts and proper torque.
