No mar plastic socket inserts #2493695
05/08/18 05:09 PM
05/08/18 05:09 PM
robertop Offline OP
robertop  Offline OP
Hey guys, anybody know of a company selling plastic inserts for socket wrenches? To be clear I mean those hexagonal inserts to use when mounting painted bolts, in my case specifically the bolts to put the hood in my bird. I know there are homemade remedies to avoid screwing the heads of the bolts, but those inserts would do the job better. I have not found anything satisfactory yet, so thanks for any suggestions.
Re: No mar plastic socket inserts [Re: robertop] #2493742
05/08/18 08:47 PM
05/08/18 08:47 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Re: No mar plastic socket inserts [Re: None2Slow] #2493800
05/08/18 11:10 PM
05/08/18 11:10 PM
robertop Offline OP
robertop  Offline OP
Thank you, None2Slow!
Re: No mar plastic socket inserts [Re: robertop] #2493886
05/09/18 10:21 AM
05/09/18 10:21 AM
western PA
stevet340 Offline
stevet340  Offline
western PA
Eastwood sells them also.
Re: No mar plastic socket inserts [Re: robertop] #2494318
05/10/18 11:23 AM
05/10/18 11:23 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The paint usually isn't shipped by the steel socket but by the pressure applied to it, which will be the same with a plastic insert. Good luck.
Re: No mar plastic socket inserts [Re: robertop] #2494329
05/10/18 11:53 AM
05/10/18 11:53 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Best way to avoid paint chips on bolts? Simple, install and adjust the bolt on painted parts (hoods, fenders, deck lids, doors, etc.) before painting the car just like the factory did. I cant for the life of me figure out why so many people restoring Mopars swim up stream on this one and paint there cars in pieces as if they were building a Chevy. If you want to cover hidden areas with paint you can always pre paint those areas and assemble the car before final paint. Why fight it?
shruggy
Re: No mar plastic socket inserts [Re: ScottSmith_Harms] #2494427
05/10/18 04:06 PM
05/10/18 04:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Might be possible to air brush the bolt heads to hide any blemishes after tightening?
Painters who have done (fill in the blank) a certain way for years are difficult to change. The ones I have dealt with either do their way or you can take your car someplace else, pretty much. Some only paint with one brand of paint and that is it, for example....
It's become incredibly difficult to get a nice quality complete paint job on an old car so people just take what they get and are grateful to get their car back
Re: No mar plastic socket inserts [Re: ScottSmith_Harms] #2494428
05/10/18 04:10 PM
05/10/18 04:10 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
shruggy
Apparently you aren't a fan of Graveyard Carz.
Re: No mar plastic socket inserts [Re: robertop] #2494562
05/10/18 11:15 PM
05/10/18 11:15 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Well if you want full, consistent coverage then you have to sacrifice chipped bolt heads. But it doesn't end there because adjusting the hinges for proper fit and closure can result in some significant paint damage. Personally I'd pre-paint the areas, bolt on and adjust everything for fit then paint the car.
Re: No mar plastic socket inserts [Re: robertop] #2494569
05/10/18 11:41 PM
05/10/18 11:41 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm (currently) a sponsor of GYC, but they dont call me for restoration advice wink
Re: No mar plastic socket inserts [Re: Neil] #2494641
05/11/18 04:32 AM
05/11/18 04:32 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Exactly!
Re: No mar plastic socket inserts [Re: ScottSmith_Harms] #2494648
05/11/18 04:47 AM
05/11/18 04:47 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
shruggy
I can think of thousands of reasons.... average guy, no lift, small garage, superbird, rotisserie resto, I am so glad my body guy will ship the car with no front fenders, let me get it running, align it, then take it back and he installs the front. It was pretty much his way or the highway on that, he did not want to repair problems later.
