What is this thing on the front of my 440 timing cover? #2494030
05/09/18 05:06 PM
05/09/18 05:06 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hi all,
Does anyone know what this thing is that's bolted to the front of my timing chain cover? This cover was included with a used 440 block I bought. The block came out of a motor home; is it something specific to motor homes or industrial engines? Thanks for any info.
Roger
Re: What is this thing on the front of my 440 timing cover? [Re: Fab64] #2494035
05/09/18 05:19 PM
05/09/18 05:19 PM
AndyF Offline
AndyF  Offline
Gun sight. It is hard to see the timing marks in a motor home so the factory put that on there to help line things up for the mechanic. Not sure if it helped or hurt.
Re: What is this thing on the front of my 440 timing cover? [Re: AndyF] #2494036
05/09/18 05:21 PM
05/09/18 05:21 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Cool, thanks!
Re: What is this thing on the front of my 440 timing cover? [Re: Fab64] #2494046
05/09/18 05:35 PM
05/09/18 05:35 PM
it almost looks hand fabbed, so the timing can be read with the "pointer" that alot of of tune up machines have for later model engines.
Re: What is this thing on the front of my 440 timing cover? [Re: Fab64] #2494053
05/09/18 05:51 PM
05/09/18 05:51 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
It is for a ignition timing tool
Re: What is this thing on the front of my 440 timing cover? [Re: CSK] #2494059
05/09/18 06:03 PM
05/09/18 06:03 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
I thought the same thing, it looks like the tube you would place the magnetic timing probe that was on some of the old Sun Analyzers.
Re: What is this thing on the front of my 440 timing cover? [Re: Fab64] #2494066
05/09/18 06:35 PM
05/09/18 06:35 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Exactly its for a magnetic pickup for timing.Wont work unless you have the setup though.Rocky
Chrysler Firepower
Re: What is this thing on the front of my 440 timing cover? [Re: Fab64] #2494092
05/09/18 07:44 PM
05/09/18 07:44 PM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
Yep, mag pickup because in some chassis, seeing the timing marks can be impossible. you should also have a slot cut into the dampener.
Re: What is this thing on the front of my 440 timing cover? [Re: ditchdrift] #2494126
05/09/18 10:00 PM
05/09/18 10:00 PM
I will never cut the outside edge of any dampener, never tsk If you do your possibly asking for future troubles with the outer ring fracturing there.
I have marked them with a marker or tape of some sort but I will never cut them after seeing pictures of Bob Glidden old Fairmount that explode a marked dampener twocents That failure lead to NHRA mandated SFI spec dampeners the next year after that work shruggy
Re: What is this thing on the front of my 440 timing cover? [Re: Cab_Burge] #2494209
05/10/18 01:01 AM
05/10/18 01:01 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
The factory cut the balancer so the magnetic pickup could read it.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: What is this thing on the front of my 440 timing cover? [Re: 3hundred] #2494230
05/10/18 02:03 AM
05/10/18 02:03 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
If I remember Chrysler had a big diagnosis machine I am thinking it was call "EPPA"? It was before DRB1 was out. There was a orange connector under the hood. It was very limited what it could do. It was supposed to have a probe for checking timing but DRB came out to replace this big machine. I never like the machine it would check the battery first and failed just about every one tested!
Re: What is this thing on the front of my 440 timing cover? [Re: 3hundred] #2494369
05/10/18 01:23 PM
05/10/18 01:23 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Robert
iagree
Wasn't just motor home engines. IIRC, most all manufacturers had them at one time. work
I do remember after I became a dealer tech that the porters were cleaning the shop one weekend and pressure-washed the old Sun machine while they were at it. shock Needless to say, it never worked right again. laugh2
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: What is this thing on the front of my 440 timing cover? [Re: SALEM1912] #2494432
05/10/18 04:20 PM
05/10/18 04:20 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
It was an EEPA, Electronic Engine Performance Analyzer. I have one and really like it.
Re: What is this thing on the front of my 440 timing cover? [Re: Fab64] #2494501
05/10/18 08:19 PM
05/10/18 08:19 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I know the BEAR D.A.C.E that used to be @ a service station I once worked @ had the mag.timing prob.
Re: What is this thing on the front of my 440 timing cover? [Re: Fab64] #2494533
05/10/18 10:12 PM
05/10/18 10:12 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We had the Aces also.had the smaller versions too.Sohio bought like 80 of each at one shot for the new service placeS they opened.They had no trouble buying equipment.We had presses fro OTC that cost the IIRc 2500 each as they had tons of adapters and had 15 or 25 ton hydraulics.Rocky
Chrysler Firepower
