Re: What is this thing on the front of my 440 timing cover?
[Re: AndyF]
#2494036
05/09/18 05:21 PM
05/09/18 05:21 PM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
Gun sight. It is hard to see the timing marks in a motor home so the factory put that on there to help line things up for the mechanic. Not sure if it helped or hurt. Cool, thanks!
[Re: Fab64]
#2494046
05/09/18 05:35 PM
05/09/18 05:35 PM
RapidRobert
it almost looks hand fabbed, so the timing can be read with the "pointer" that alot of of tune up machines have for later model engines.
[Re: Fab64]
#2494053
05/09/18 05:51 PM
05/09/18 05:51 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
It is for a ignition timing tool
[Re: Fab64]
#2494066
05/09/18 06:35 PM
05/09/18 06:35 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Exactly its for a magnetic pickup for timing.Wont work unless you have the setup though.Rocky
Chrysler Firepower
[Re: ditchdrift]
#2494126
05/09/18 10:00 PM
05/09/18 10:00 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
you should also have a slot cut into the dampener. I will never cut the outside edge of any dampener, never ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) If you do your possibly asking for future troubles with the outer ring fracturing there. I have marked them with a marker or tape of some sort but I will never cut them after seeing pictures of Bob Glidden old Fairmount that explode a marked dampener ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) That failure lead to NHRA mandated SFI spec dampeners the next year after that
[Re: Cab_Burge]
#2494209
05/10/18 01:01 AM
05/10/18 01:01 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
The factory cut the balancer so the magnetic pickup could read it.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2494230
05/10/18 02:03 AM
05/10/18 02:03 AM
Posts: 862 Southeast Pa.
SALEM1912
Southeast Pa.
If I remember Chrysler had a big diagnosis machine I am thinking it was call "EPPA"? It was before DRB1 was out. There was a orange connector under the hood. It was very limited what it could do. It was supposed to have a probe for checking timing but DRB came out to replace this big machine. I never like the machine it would check the battery first and failed just about every one tested!
[Re: 3hundred]
#2494369
05/10/18 01:23 PM
05/10/18 01:23 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
Robert ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Wasn't just motor home engines. IIRC, most all manufacturers had them at one time. ![work work](/ubbthreads/images/graemlins/custom/work.gif) I do remember after I became a dealer tech that the porters were cleaning the shop one weekend and pressure-washed the old Sun machine while they were at it. ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif) Needless to say, it never worked right again. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) )
[Re: SALEM1912]
#2494432
05/10/18 04:20 PM
05/10/18 04:20 PM
Posts: 10,759 North Dakota
6PakBee
North Dakota
If I remember Chrysler had a big diagnosis machine I am thinking it was call "EPPA"? It was before DRB1 was out. There was a orange connector under the hood. It was very limited what it could do. It was supposed to have a probe for checking timing but DRB came out to replace this big machine. I never like the machine it would check the battery first and failed just about every one tested! It was an EEPA, Electronic Engine Performance Analyzer. I have one and really like it.
[Re: Fab64]
#2494533
05/10/18 10:12 PM
05/10/18 10:12 PM
therocks
Niles , Ohio
We had the Aces also.had the smaller versions too.Sohio bought like 80 of each at one shot for the new service placeS they opened.They had no trouble buying equipment.We had presses fro OTC that cost the IIRc 2500 each as they had tons of adapters and had 15 or 25 ton hydraulics.Rocky
Chrysler Firepower
