727 Gurus...Help Please! #2492751
05/06/18 12:32 PM
05/06/18 12:32 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
I went under my Goddaughter's '70 Duster (360/727) to do an oil change and saw this.
Looks like a sleeve/bushing/collar worked it's way out the back and took the seal with it.
Why would this happen? Can I just shove it back in and replace the seal? The trans has roughly 6000 miles on it.
Re: 727 Gurus...Help Please! [Re: vdriver] #2492759
05/06/18 12:50 PM
05/06/18 12:50 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
That driveshaft is too short, causing this problem. I would pull that bushing , install new if it fits tight and get a longer driveshaft.
Re: 727 Gurus...Help Please! [Re: vdriver] #2492762
05/06/18 12:57 PM
05/06/18 12:57 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Thanks for the reply. That pic might be deceptive cuz the front of the car is way up in the air. The shaft has roughly 3/4" of travel.
Re: 727 Gurus...Help Please! [Re: vdriver] #2492763
05/06/18 12:59 PM
05/06/18 12:59 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
If the aluminum housing bore is all spun out from bushing spinning, it kinda looks like it, you will need a new tailshaft housing.
Re: 727 Gurus...Help Please! [Re: vdriver] #2492764
05/06/18 01:01 PM
05/06/18 01:01 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Travel sounds spot on, but it should only be 1" out from seal with car sitting on its rear suspension, that looks like at least 3".
Re: 727 Gurus...Help Please! [Re: vdriver] #2492770
05/06/18 01:21 PM
05/06/18 01:21 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I had better be more clear here, with car sitting on its suspension you bottom the yoke in the transmission, pull out 1", measure center to center of u-joints for driveshaft length. Some after market seals have an additional dust seal that is about an 1" longer so 1" from seal would be incorrect on those.
Re: 727 Gurus...Help Please! [Re: vdriver] #2492785
05/06/18 01:44 PM
05/06/18 01:44 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Looks like too short of shaft from here too. If the housing will still hold tight to a new bushing, you can rent one of them driver/installer tools that will remove or install bushing with housing still on trans. We used them at trans shop, and cannot recall who mfgd it.(tool)
Re: 727 Gurus...Help Please! [Re: vdriver] #2492786
05/06/18 01:44 PM
05/06/18 01:44 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Thanks for all the info. I'll be checking it out later today.
Re: 727 Gurus...Help Please! [Re: vdriver] #2492804
05/06/18 02:35 PM
05/06/18 02:35 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I agree with the others.
3/4 inch movement is fine, but that yolk is sticking way out the back of the tail shaft. Gotta wonder how much spline engagement there is.
Good thing you found this before it blew apart on the road.
I have mechanical Aptitude.
I can screw up anything.
Re: 727 Gurus...Help Please! [Re: vdriver] #2492832
05/06/18 04:22 PM
05/06/18 04:22 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I think you will find the bushing is siezed on the yoke. Why does the yoke look black and rough when I blow up your pic? You didn't paint or undercoat it did you?
Re: 727 Gurus...Help Please! [Re: vdriver] #2493315
05/07/18 06:27 PM
05/07/18 06:27 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Who rebuilt the transmission ?? With that low mileage, whoever did the tranny should still warranty it . . . you would think . . . .
Re: 727 Gurus...Help Please! [Re: vdriver] #2494049
05/09/18 05:38 PM
05/09/18 05:38 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Is that rust pits on the seal surface of the yoke?
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
