Rear shocks that are longer? Dodge truck? #249217
03/10/09 05:02 AM
03/10/09 05:02 AM
abodyman Offline OP
super street
abodyman  Offline OP
super street
Hi Guys,
maybe You all remember my car leans really bad when going slow around right hand turns, consequently rubbing the left rear tire on the inside of the wheelwell.
Ok, I ordered a complete front suspension rebuild.
But couldnt order any one kit, because its made up of bigger front ball joints, offset upper bushings, early lower ball joints and 74 chrysler rod ends.. anyhow, tomorrow I am also ordering new heavier torsion bars from Firm Feel, since they are close by..
Now about the rear shocks.
I currently have an 8 3/4 rear, narrowed, with 3000 lbs super stock springs moved into the frame rails
Mickey Thompson ET 13.5x15x30 inch tires. also 6 cylinder torsion bars.
When I put it together, the front passenger fender sat higher up in the air,than the drivers side for some reason. I was in a hurry and just shoved down hard on the fender and a loud "PoP" sound happened...so I think the lower bushing may be loose/broken?
The rear tires and
Everything clears fine, until I make a right turn.
I think its something with the front suspension being worn out or put together wrong.
and the Mopar Performance rear Super stock gas shocks
probably are not helping either.
They are whats recommended, from the place I bought them.
What I want to find, is a shock thats going to hold up, and actually create some H.D. damping
from like a truck or something?
I remember a post...but cannot find it, of course about a few of You guys running with rear truck shocks as they are longer and heavier?
From some year of Dodge truck? mid 90"s?
I just want to see, if thats part of the problem with my car and want to try them to see if it helps any.
It sure can't hurt any!
I don't know what year of dodge truck or anything to look for.
Sorry for the long letter and explanation.
I'm all out of ideas.
If none of this stuff will work, then I have to start with different tires and wheels and maybe a different rear housing or springs.
I thought I would take the inexpensive easy route first. I still havent even seen how fast this will go, and its been running for 2 years now!
It would be nice to finally take it for even a test and tune!
Thanks as always!
Re: Rear shocks that are longer? Dodge truck? [Re: abodyman] #249218
03/10/09 05:37 AM
03/10/09 05:37 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
ive got the mid 90's ram truck shocks on mine. You have to mod the upper bushing sleeves in them. They are stiff ..but mine aint a Cadillac.
also the SS springs will make the car a bit higher on the pass side (rear).
Re: Rear shocks that are longer? Dodge truck? [Re: 493_DART] #249219
03/10/09 07:30 AM
03/10/09 07:30 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
We used Monroe gas shocks for a 72 Monaco with the Police package. They are 2" longer than stock on a B body. Go to Rock Auto's site and check out their shocks. They list the end-types and length for most shocks that they sell.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Rear shocks that are longer? Dodge truck? [Re: Dads426] #249220
03/10/09 01:21 PM
03/10/09 01:21 PM
abodyman Offline OP
super street
abodyman  Offline OP
super street
Hey Thanks Guys!
I will check rock auto out.
again, sorry about the long post I wrote,
there is just so many things WRONG with my car!
Re: Rear shocks that are longer? Dodge truck? [Re: abodyman] #249221
03/10/09 06:10 PM
03/10/09 06:10 PM
ohio
1Bad440 Offline
1Bad440  Offline
ohio
2000 Dodge Ram 3/4 ton stock replacement from Napa. I did have to rework the rubber bushings.
