Re: Mini tubbed 63-65 B bodies how wide is you axle housing
[Re: biff426]
#2491522
05/03/18 03:09 PM
05/03/18 03:09 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
The 1965 B body rear end is the best stock rear end housing to use on the 1962 to 1965 B bodies All the rest of the 1966 and later axle housing , including the 1965 station wagon rear ends, are wider As far as what your asking on how wide of rims (the offsets will be determine after determining the width ) and what tire size do you want to use? I would take a carpenter square pushed up against the axle with the brake drum on and measure from the inner surface of it to the narrowest part of the inner wheel wheels on the inside and the outside to determine what wheel width I could use on that car and go from there The wider the wheel width you use the straighter the section width will be using the same size tire size on different wheel widths I haven't messed with a 1965 Dodge B body in a long time so I can't really tell you what you want to know exactly Hopefully some one else with real knowledge on your car will chime in with some helpful advise on this
[Re: biff426]
#2491552
05/03/18 04:10 PM
05/03/18 04:10 PM
Posts: 30,998 Oregon
AndyF
I am trying to finish up my 65 coronet and need to get the rear cut. It is mini tubbed and the springs moved into the frame. What do you guys have for a housing width and what width wheel are you using and backspacing? I don't want the wheel/tire to be too far under I like the look of the tire being out close to the wheel lip. I don't have wheels yet so I am starting from scratch. Any help much appreciated. I use a factory B-body Dana 60 under my '65 with a 315/45-17 tire.
[Re: biff426]
#2491567
05/03/18 04:19 PM
05/03/18 04:19 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
I used the stock 65 8 3/4 width when I made my Dana 60 out of a truck housing
I have Andy Fâs old steel 15x10 wheels with 325/50-15 s
[Re: Cab_Burge]
#2491624
05/03/18 06:28 PM
05/03/18 06:28 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The 1965 B body rear end is the best stock rear end housing to use on the 1962 to 1965 B bodies All the rest of the 1966 and later axle housing , including the 1965 station wagon rear ends, are wider '65-'67 B-body, all body styles, same same. '62 and '63 are an inch narrower but have the taper axles.
[Re: AndyF]
#2491698
05/03/18 09:39 PM
05/03/18 09:39 PM
NTOLERANCE
Madison Wi
That is cool. I'd forgotten where those rims went. I had them custom built to fit my car with a stock width rearend so they probably fit your car pretty well. This was the day the car got its parole. Soon. Very soon
[Re: biff426]
#2491754
05/03/18 11:27 PM
05/03/18 11:27 PM
NTOLERANCE
Madison Wi
65 coronet with a mini tub on a 15â wheel have about 7â of back space.
About 6.75 or so as I recall. I can measure mine soon if it helps.
[Re: topside]
#2491761
05/03/18 11:37 PM
05/03/18 11:37 PM
Posts: 4,669 Wichita
GY3
Wichita
I'd recommend you decide on a wheel & tire, and mock up from there. Most wheels are only available in certain backspaces & widths, and/or the custom sizes are pretty expensive. Exactly!
[Re: biff426]
#2492035
05/04/18 03:32 PM
05/04/18 03:32 PM
Posts: 8,237 fredericksburg,va
cudaman1969
fredericksburg,va
find the tire that will fit the wheel well, then a rim that will give a normal sidewall bulge and backspace. Bolt axels to the rim (old set cut shorter works great) slide a pipe over the axels to keep straight, let the car down on the tire combo then move or position them to where they fit with good clearance all around at ride height. Then measure to both backs of rim, there's your size to make the housing. There are no shortcuts unless someone has the identical setup you want (not often)
[Re: biff426]
#2492038
05/04/18 03:36 PM
05/04/18 03:36 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I buy my wheels/tires first and do the rear after. Since I do my own narrowing also, I do that first, then axles last in case my measurements are off
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#2492054
05/04/18 04:17 PM
05/04/18 04:17 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
I buy my wheels/tires first and do the rear after. Since I do my own narrowing also, I do that first, then axles last in case my measurements are off This is how I did mine but on an E Body. We made the wheels fit the car. Mine are 15' X 12" with a 6.5" B.S.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
