So does this 67-68 Hemi trans number look correct ? #2489775
04/30/18 12:04 AM
04/30/18 12:04 AM
blewbyu Offline OP
blewbyu  Offline OP
So I am looking at this tranny correct for 67-68 Auto Hemi cars 2801544
I found this tranny and have alot of questions about pan rail number. I have never seen an H before the part number only a PK. Also it should have number 2 before the 333 for a date code, did it just not get stamped.
Re: So does this 67-68 Hemi trans number look correct ? [Re: blewbyu] #2489792
04/30/18 12:59 AM
04/30/18 12:59 AM
blewbyu Offline OP
blewbyu  Offline OP
I did find this old thread on here just now talking about the H before part number and the first number of the date code missing.
So it should be all correct maybe?
https://board.moparts.org/ubbthreads/ubbt...g-question.html
Re: So does this 67-68 Hemi trans number look correct ? [Re: blewbyu] #2490218
05/01/18 12:46 AM
05/01/18 12:46 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Blewbyu,
Just for comparison, my numbers are a bit faint but still readable. This is the original hemi trans for my 68 RR (May 68 build).
PK2801544K 2413 0178 I had in my notes that it decoded to 6 March 1968, #178 built that day/shift.
Re: So does this 67-68 Hemi trans number look correct ? [Re: 68jim] #2490265
05/01/18 03:07 AM
05/01/18 03:07 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By 68jim
Blewbyu,
I have two 68 Hemi transmissions and the two 4s look identical like this one.
Re: So does this 67-68 Hemi trans number look correct ? [Re: blewbyu] #2490301
05/01/18 09:41 AM
05/01/18 09:41 AM
blewbyu Offline OP
blewbyu  Offline OP
Does anyone have a picture of a 67 tranny with a H on it that they could post?
Re: So does this 67-68 Hemi trans number look correct ? [Re: blewbyu] #2490308
05/01/18 10:11 AM
05/01/18 10:11 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
My understanding is that if it has an "H" or "J" before the number it is a 67 trans, if "PK" it is 68 and later. twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: So does this 67-68 Hemi trans number look correct ? [Re: Rhinodart] #2490552
05/01/18 05:14 PM
05/01/18 05:14 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
in a recent thread there was a comment about the non-"PK" stampings being calendar year, & if the first digit of the date is missing on the 10,000 day calendar we would have the following:
(2)333 = Sunday 12/17/67 (H 1967 calendar year)
(2)361 = Sunday 1/14/68 (J 1968 calendar year)
(2)379 = Thursday 2/1/68 (J 1968 calendar year)
any of these that would've been factory installed in a 1968 model year car should have a partial VIN stamped on the top of the bell housing area
H2801544 3337888 68_Hemi_Trans.jpgmoparts J2801544 3615583 727 trans.jpgmoparts 1967-68 J2801544 3797557.jpgmoparts transmission stamp 1968.png
Re: So does this 67-68 Hemi trans number look correct ? [Re: 6bblgt] #2490554
05/01/18 05:19 PM
05/01/18 05:19 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
work
perhaps the date & unit # format was changed between the above February '68 & March '68 dated transmissions
February 1 (1st week of month & weekly unit number)
March 6 (dated daily & daily unit number)
any close examples any engines?
Re: So does this 67-68 Hemi trans number look correct ? [Re: 6bblgt] #2490557
05/01/18 05:23 PM
05/01/18 05:23 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
work work
& of note is the suffix "K" on the part number of the March '68 transmission, which changed to "L" at some point & seemed to continue as a "L" for a number of years
is this a progression of the year prefix "H" "J" seen on the other transmissions, that became obsolete but remained for no purpose shruggy
Re: So does this 67-68 Hemi trans number look correct ? [Re: 6bblgt] #2490572
05/01/18 06:02 PM
05/01/18 06:02 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
'62 or '63 727 Max Wedge transmission
Originally Posted By mr426427
Galen's book is wrong on 62 and 63 max wedge trannys. 007 is the correct number for 63 model year cars. 007 was used in the 300J along with 63 max wedge cars. the second number is not a date code either as Galen has always suggested. It is simply a continuing assembly number that is carried on year after year. the C suggests it was assembled in the second half of the 62 calendar year. a D in front of it would indicate the first half of 63. then E and F would be the 64 model year, G and H would be the 65 model year, etc. I think your tranny could very well have been out of a 300J that was likely assembled late in 62 or early 63. it would fit a lot of max wedge cars built around the same time frame. it should be worth at least 500 hundred dollars to someone trying to make a maxie as correct as possible.
C * 1962
D * 1963
E * 1964
F * 1965
G * 1966
H * 1967
J * 1968
shruggy
0571745
10,000 day calendar
0571 = Tuesday 2/19/63 * ?? - unit # 745
(0)057 = Saturday 9/23/61 doesn't fit with 9/62 casting - unit # 1745
(1)057 = Friday 6/19/64 fits as a replacement part - unit # 1745
none of these fit with the "C" being full or second half of '62 calendar year
Re: So does this 67-68 Hemi trans number look correct ? [Re: 6bblgt] #2490697
05/02/18 12:14 AM
05/02/18 12:14 AM
blewbyu Offline OP
blewbyu  Offline OP
Here is another tranny I have H2801541 3395749
I assume this is 12-23-67 correct for a 68 440?
Re: So does this 67-68 Hemi trans number look correct ? [Re: blewbyu] #2490709
05/02/18 12:38 AM
05/02/18 12:38 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
So when did PK start? What does it mean?
A-Body's RULE!
Re: So does this 67-68 Hemi trans number look correct ? [Re: Rhinodart] #2490713
05/02/18 12:46 AM
05/02/18 12:46 AM
blewbyu Offline OP
blewbyu  Offline OP
PK = Kokomo
I was told that this was where it was made?
Re: So does this 67-68 Hemi trans number look correct ? [Re: blewbyu] #2490799
05/02/18 09:45 AM
05/02/18 09:45 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have heard that also, so the other transmissions were built where? shruggy
A-Body's RULE!
Re: So does this 67-68 Hemi trans number look correct ? [Re: Rhinodart] #2490811
05/02/18 10:27 AM
05/02/18 10:27 AM
blewbyu Offline OP
blewbyu  Offline OP
My WAG is
H = Harlem
J = Jerico
haha
Re: So does this 67-68 Hemi trans number look correct ? [Re: blewbyu] #2491171
05/02/18 11:04 PM
05/02/18 11:04 PM
A727Tflite Online content
A727Tflite  Online Content
Including more recent builds like front wheel drive and so earlier units, we had a transmission plant in Mexico (Toluca) and we had the original Syracuse plant that built the manuals (NPG = new process gear) - those transmission from NPG had the PP stamped in them.
NPG later because NVG = New Venture Gear when we partnered with GM.
