So does this 67-68 Hemi trans number look correct ?
#2489775
04/30/18 12:04 AM
04/30/18 12:04 AM
Posts: 4,282 Florida
blewbyu
So I am looking at this tranny correct for 67-68 Auto Hemi cars 2801544 I found this tranny and have alot of questions about pan rail number. I have never seen an H before the part number only a PK. Also it should have number 2 before the 333 for a date code, did it just not get stamped.
Re: So does this 67-68 Hemi trans number look correct ?
[Re: 68jim]
#2490265
05/01/18 03:07 AM
05/01/18 03:07 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Blewbyu,
Just for comparison, my numbers are a bit faint but still readable. This is the original hemi trans for my 68 RR (May 68 build). PK2801544K 2413 0178 I had in my notes that it decoded to 6 March 1968, #178 built that day/shift. I have two 68 Hemi transmissions and the two 4s look identical like this one.
[Re: 6bblgt]
#2490554
05/01/18 05:19 PM
05/01/18 05:19 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
perhaps the date & unit # format was changed between the above February '68 & March '68 dated transmissions February 1 (1st week of month & weekly unit number) March 6 (dated daily & daily unit number) any close examples any engines?
[Re: 6bblgt]
#2490572
05/01/18 06:02 PM
05/01/18 06:02 PM
6bblgt
Las Vegas, NV
'62 or '63 727 Max Wedge transmissionGalen's book is wrong on 62 and 63 max wedge trannys. 007 is the correct number for 63 model year cars. 007 was used in the 300J along with 63 max wedge cars. the second number is not a date code either as Galen has always suggested. It is simply a continuing assembly number that is carried on year after year. the C suggests it was assembled in the second half of the 62 calendar year. a D in front of it would indicate the first half of 63. then E and F would be the 64 model year, G and H would be the 65 model year, etc. I think your tranny could very well have been out of a 300J that was likely assembled late in 62 or early 63. it would fit a lot of max wedge cars built around the same time frame. it should be worth at least 500 hundred dollars to someone trying to make a maxie as correct as possible. C * 1962 D * 1963 E * 1964 F * 1965 G * 1966 H * 1967 J * 1968 0571745 10,000 day calendar 0571 = Tuesday 2/19/63 * ?? - unit # 745 (0)057 = Saturday 9/23/61 doesn't fit with 9/62 casting - unit # 1745 (1)057 = Friday 6/19/64 fits as a replacement part - unit # 1745 none of these fit with the "C" being full or second half of '62 calendar year
[Re: 6bblgt]
#2490697
05/02/18 12:14 AM
05/02/18 12:14 AM
blewbyu
Here is another tranny I have H2801541 3395749
I assume this is 12-23-67 correct for a 68 440?
[Re: blewbyu]
#2490709
05/02/18 12:38 AM
05/02/18 12:38 AM
Posts: 43,522 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
So when did PK start? What does it mean?
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2490713
05/02/18 12:46 AM
05/02/18 12:46 AM
blewbyu
So when did PK start? What does it mean? PK = Kokomo I was told that this was where it was made?
[Re: Rhinodart]
#2490811
05/02/18 10:27 AM
05/02/18 10:27 AM
blewbyu
I have heard that also, so the other transmissions were built where? My WAG is H = Harlem J = Jerico
