Tie Rod taper
#2488824
04/27/18 09:21 PM
04/27/18 09:21 PM
Posts: 383 Essex, Ont., Canada
Fishmarket
Essex, Ont., Canada
Does anyone know what the tie rod taper is in degrees for our old moparts? I’m trying to adapt a bump steer kit to my 1970 duster and need to know if one of the available kits could made to work or if I need to ream the lower ball joints. I read somewhere that pinto tie rods had the same angle, I believe 7.15* , but I’m not positive and can’t seem to find anything on the google machine. Thx
1972 Plymouth Cuda 340 4 speed
1971 Plymouth Road Runner 383 Auto
1970 Plymouth Duster /6 Auto
Re: Tie Rod taper
[Re: Fishmarket]
#2488857
04/27/18 11:01 PM
04/27/18 11:01 PM
RapidRobert
Worst case you might get one of our tie rods & the furd one at your parts house & compare em on the counter.
Re: Tie Rod taper
[Re: Fishmarket]
#2488948
04/28/18 03:08 AM
04/28/18 03:08 AM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
Speedway Motors have what you need. yes it is the same as an old 70's mustangII pinto
