Tie Rod taper #2488824
04/27/18 09:21 PM
04/27/18 09:21 PM
Essex, Ont., Canada
Fishmarket Offline OP
Essex, Ont., Canada
Does anyone know what the tie rod taper is in degrees for our old moparts? I’m trying to adapt a bump steer kit to my 1970 duster and need to know if one of the available kits could made to work or if I need to ream the lower ball joints. I read somewhere that pinto tie rods had the same angle, I believe 7.15* , but I’m not positive and can’t seem to find anything on the google machine.
Thx
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: Tie Rod taper [Re: Fishmarket] #2488857
04/27/18 11:01 PM
04/27/18 11:01 PM
Worst case you might get one of our tie rods & the furd one at your parts house & compare em on the counter.
Re: Tie Rod taper [Re: Fishmarket] #2488935
04/28/18 02:05 AM
04/28/18 02:05 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I believe the degrees of tapper is 7*. When I redid the tapper on a set of steering arms on an old truck, I just used a tapper deburr cutter on a die grinder and removed the material slowly until the tie rod end fit tightly and the nut would tighten without bottoming out. You just need to tapper the hole enough to get the cotter key in when the nut is tight. Its not like it can fall out or wobble around (unless to get carried away). Gene
Re: Tie Rod taper [Re: Fishmarket] #2488944
04/28/18 02:38 AM
04/28/18 02:38 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Taper.
Re: Tie Rod taper [Re: Fishmarket] #2488948
04/28/18 03:08 AM
04/28/18 03:08 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Speedway Motors have what you need. yes it is the same as an old 70's mustangII pinto
Re: Tie Rod taper [Re: Fishmarket] #2488972
04/28/18 09:54 AM
04/28/18 09:54 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have the Mustang II 7 degree on my 64. You may have to grind the bottom of steering arm. On mine the hex at the bottom of the tapered adapter contacted the arm before the taper was seated. We cut the original tie rod sleeves in half. These were welded to 5/8" threaded tube. The tube threads on the high misalignment hiems. All parts came from Speedway.
Doug
Re: Tie Rod taper [Re: Fishmarket] #2489018
04/28/18 12:01 PM
04/28/18 12:01 PM
Essex, Ont., Canada
Essex, Ont., Canada
Awesome, thanks a bunch!
