Dana 60 #2487502
04/24/18 09:30 PM
04/24/18 09:30 PM
usa,pa
jkwedge540 Offline OP
usa,pa
Working on a Dana 60. It has moser axles and a spool. My question is should the axle move with the retainer bolted in. The axles moves about and 1/8 or better.
Re: Dana 60 [Re: jkwedge540] #2487512
04/24/18 09:42 PM
04/24/18 09:42 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I would think not. What's moving? Bearings not being retained and allowed to move? What kind of bearings?
Re: Dana 60 [Re: jkwedge540] #2487526
04/24/18 10:17 PM
04/24/18 10:17 PM
usa,pa
usa,pa
I think they are ones moser sells. The bearing moves in the housing. The bearing has a o ring on it and on the retainer side there is a step in the bearing like it should fit in the retainer.
Re: Dana 60 [Re: jkwedge540] #2487532
04/24/18 10:26 PM
04/24/18 10:26 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
It should have a retaining clip on the outer race
Re: Dana 60 [Re: The Shadow] #2487545
04/24/18 10:43 PM
04/24/18 10:43 PM
usa,pa
usa,pa
There is no retaining clip. Everything looks good except for the movement.
Re: Dana 60 [Re: jkwedge540] #2487606
04/25/18 01:05 AM
04/25/18 01:05 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Sounds like you have first generation (RP 400) Green bearings with the 5-hole retainer broken off. You probably need a new pair of snap-ring style (MO 400) Green bearings.
Re: Dana 60 [Re: DoctorDiff] #2487663
04/25/18 08:12 AM
04/25/18 08:12 AM
usa,pa
usa,pa
You have any pics of what I need . Thanks
Re: Dana 60 [Re: jkwedge540] #2487667
04/25/18 08:54 AM
04/25/18 08:54 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I had the same problem. The outer retainer is wider than the bearing race. You can fabricate a spacer shim, but the right way is to install the snap ring style bearing to keep it located.
[image][/image]
Re: Dana 60 [Re: jkwedge540] #2487925
04/25/18 07:31 PM
04/25/18 07:31 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
It's just a bearing with a groove for a snap-ring and a retainer flange separate from the bearing.
It's not a one piece like the old "green" bearings.
Gus beer
64 Plymouth Savoy
Dana 60
